APS Upgrade Team Tests Move of Heavy Components into Storage Ring
The new storage ring built for the Advanced Photon Source (APS) Upgrade Project at the U.S. Department of Energy’s Argonne National Laboratory will be made up of 1,321 precisely aligned magnets. They, and all associated electrical, water, and vacuum systems will be assembled into three types of a total of 200 modules, all mounted to concrete platforms called plinths, and then transported from the assembly area to the APS storage ring. It takes specialized equipment to make the move safely and efficiently.
 An APS Upgrade team successfully moved one of the larger plinths – nearly 20 feet long and weighing roughly 30,000 pounds before the heavy magnets (which add another 10,000 pounds) are assembled atop it – in order to test that equipment, and make sure it could maneuver the plinth through doorways and into the storage ring area.
They transported the plinth to the APS by truck (photo 1) and moved it using a PowerAttack device (photo 2), an alternative to traditional forklift technology, to maneuver a plinth through doorways and into the storage ring at the heart of the APS.
The plinths will be moved, one by one, into the APS storage ring facility during the one-year shutdown for the APS Upgrade. This test run helped the APS-U team determine how to maneuver the completed modules into the ring (photo 3).
“It all worked out very well,” said Ralph Bechtold, principal mechanical engineering specialist with the APS Upgrade.  (All photos by Ralph Bechtold, Argonne National Laboratory)
The Advanced Photon Source is a DOE Office of Science User Facility operated for the DOE Office of Science by Argonne National Laboratory under Contract No. DE-AC02-06CH11357
