Source Properties | ||||||||||||||||||||
SmCo permanent magnet undulator
Optical Components | ||||||||||||||||||||
Beam Properties | ||||||||||||||||||||
X-ray energy
Beam size
Photon Flux
Control Software | ||||||||||||||||||||
Beamline 4-ID-D uses the EPICS platform for beamline control. This is a distributed client-server software where seperate server computers (IOCs) are used to control and monitor different portions of the beamline, and a separate client computer is used for data aquisition and display information. The client computer controls the other IOCs via the local ethernet network. The EPICS client "MEDM" is used for graphically displaying information about the beamline. The command line driven program SPEC is used for scanning and other data acquisition functions. More information on each of these is found below.
Data Analysis Tools | ||||||||||||||||||||
Scans from SPEC data files can be displayed at the beamline using several different plotting packages |
Techniques and Experimental Setups | ||||||||||||||||||||
Magnetic Scattering Techniques:
Setups:
Magnetic Spectroscopy Techniques:
Setups:
