Command |
Function |
Call sequence |
Screen Plot Macros: (plot_extras_2.2.mac) | ||
splot_abs | Plots-log(DET/MON) of last scan on the screen | splot_abs |
splot_deriv | Plots the derivative of the last scan. | splot_deriv [-1] |
splot_dabs | Plots the derivative of-log(DET/MON) of last scan | splot_dabs |
Printer Plot Macros: (cplot_xor_3.3.mac) | ||
cplot_plot | Prints a plot of the last scan | cplot_plot |
cplot_abs | Prints absorption plot {-log(DET/MON)} of last scan | cplot_abs |
cplot_deriv | Prints plot of the derivative of last scan. |
cplot_deriv [-1] |
cplot_dabs | Prints a plot of the derivative of the absorption |
cplot_dabs |
Slit Macros: (slits_xor_1.4.mac) | ||
showslits | Displays current slit positions. | showslits |
setslit | Set slit size [and position] | setslit slitmne hsize vsize [hpos vpos] |
slitscan | Scan a slit blade, center, or position. | slitscan slitmne what strt fin steps time |
confslits | Define which slits to control in SPEC | confslits |
Filter Macros: (filters_2.0. mac) | ||
filter | Sets filter position; 1 or 4 args. (i.e. 9 same as 1001) | filter filtmne # or [0/1 0/1 0/1] |
showfilters | Displays current filter positions. | showfilters |
Temp Control Macros: (Temperature_2.5.mac) | ||
te | Show temperature or set setpoint. | te [setpoint] |
changetemp | Change temperature to value (waits before next cmd.) | changetemp temp [delta delay] |
tempscan | Scans temperature. | tempscan strt fin steps time |
ramp | Turns on ramp or Sets ramp rate. | ramp [on/off] or [rate] |
heater | Sets heater range. | heater [0to5] or off |
save_temp_on[off] | Save [not] temperature in data file. | save_temp_on |
lakeshore1(2) | Switches between lakeshores (2)-> 4 sensor | lakeshore1(2) |
Undulator Macros: (undulators_1.3.mac) | ||
moveundE | Move undulator energy (with backlash). | moveundE E |
undscan | Scan the undulator in energy. | undscan startE stopE steps time |
undscangap | Scans undulator gap. | undscangap start stop steps time |
und_setup | Give offset for energy moves. | und_setup |
und_tracking_on[off] | Turn on[off] undulaor tracking of mono | und_tracking_on |
MCA Macros: (epics_mca_3.3.mac) | ||
MCAscanpt | Takes an mca spectra for each point in scan. | MCAscanpt scan+ args |
MCAscanend | Takes an mca spectra at end of scan | MCAscanend scan+args |
getaandsavemca | Takes mac spectra and saves it to datafile. | getandsavemca time |
mca_setup | Define which mca to control. | mca_setup |
Analyzer Macros: (analyzer_1.1.mac) | ||
analyzer_setup | Define analyzer d spacing and type. | analyzer_setup [ana_d] [ana_type] |
analyzer_on [_off] | Have analyzer track in energy [ not]. | analyzer_on |
asetE | Set analyzer ath and atth positions for given energy. | aseE E |
calc_anal | Show ath and atth positions for given energy | calc_anal E |
go_sigma [_pi] | Move polarization type analyzer sigma or pi position | go_sigma |
Disable Macros: (disable_1.11.mac) | ||
disable | Disables a motor or counter. Use? to show. | disable [det1 det2...] or ? |
enable | Enable a disabled motor or counter. | enable [det1 det2...] or ? |
![ANL Home](https://www.aps.anl.gov/sites/www.aps.anl.gov/files/APS-Uploads/anl_logo_head.png)
