The following conditions must be met before a Search and Secure can be performed:
- No faults or trips are indicated on the System Control Panel.
- The EMERGENCY BEAM STOP button is not depressed.
- The DOOR DISABLE button is not depressed.
- The station doors are in the correct state.
- The beam mode is correct (if applicable).
Each station has one or more numbered search boxes inside.Each box has a button that must be pressed as the search of the station progresses.When the conditions listed above are met, an amber light will start flashing above search box number 1.
