Lesson Module A-10: Required Beamline Cabinet Information - pg 3
For operational beamlines the following information must be posted:
  • Experiment Approval Safety Form (ESAF) or APS Beamline Operations Approval Form: Now replaces the CAA for beamlines designated as being operational.
  • Configuration Control Component List (CCCL): The list showing all components that are under configuration control is required for beamlines, operational or commissioning.The matching color-coded map again accompanies the CCCL.
  • Anamorphic bremsstrahlung ray traces: Drawings in both the horizontal and vertical plane that project the radiation source through all apertures (optical stops) until the final bremsstrahlung stop is reached are still needed. Note: Some beamlines' ray traces are available via ICMS instead of the beamline end cabinets.
  • Please note:
    • The Shielding Verification Plan is no longer needed.
Next
