X-ray Spectroscopy Special Interest Group (SIG) - ESRF-EBS and spectroscopy, examples with beamlines BM23 and ID24
Type Of Event
Meeting
Sponsoring Division
APS
Location
Virtual
Speaker
Olivier Mathon, European Synchrotron Radiation Facility
Host
Mary Upton and Yanna Chen
Start Date
12-11-2024
Start Time
11:00 a.m.
Description
Abstract:
BM23 and ID24 are two ESRF beamlines dedicated to hard X-ray Absorption Spectroscopy (XAS). BM23 is a multi-purpose EXAFS beamline based on a two-poles wiggler source. BM23 is optimized for high quality XAS measurements between 5 and 90 keV, in transmission or fluorescence mode. ID24 is based on an undulator source and is composed of two branches, ID24-ED and ID24-DCM. ID24-ED is an energy dispersive XAS beamline, optimised for ultrafast XAS measurements down to the single bunch (100 ps), thanks to the high flux up to 1013 ph/s from the undulator source. The main application is the study of matter under laser induced dynamic compression, generated by the High Power Laser Facility (HPLF). ID24-DCM is a high brilliance XAS beamline based on a next generation scanning Double Crystal Monochromator (DCM). The accessible X-ray energy ranges from 5 to 45 keV. Taking advantage of the new EBS characteristics, this branch of ID24 beamline combines high flux up to 1013 ph/s from undulator source with variable X-ray beam size from 1x1mm2 down to 500x500 nm2 FWHM. After a brief introduction of ESRF-EBS and spectroscopy activities at ESRF, I will describe the two beamlines and will highlight the main modifications performed in the setup following the implementation of the ESRF-EBS source. I will describe in particular the beamline ID24-DCM, anew beamline optimized for ESRF-EBS and I will present in details the new DCM developed by ESRF through recent technical and scientific results.
To report an event that is not listed, please contact webmaster, for additional synchrotron-related conferences, check lightsources.org.
