Calculated Details of the Design Parameters for the Storage Ring Sextupole Magnet at 7.7 GeV
Calculations derived using program MADEST.
Number of magnets |
280 |
Type of magnet |
Sextupole |
Type of excitation |
DC |
Maximum multipole field gradient |
445 |
T/m2 |
DESIGN AND OPERATING PARAMETERS OF A SINGLE MAGNET:
Gap
Effective length of field along gap axis |
24.1 |
cm |
Total width of pol |
4.38 |
cm |
Total bore radius |
4.9 |
cm |
Core
Distance from - Field edge to - Core end |
1.55 |
cm |
- Pole side |
-.30 |
cm |
- Coil to - Pole face |
3.288 |
cm |
- Pole side |
-0.8 |
cm |
- Top yoke |
-.08 |
cm |
- Side yoke |
.32 |
cm |
- Endplate end |
2.22 |
cm |
Pole radius |
2.768 |
cm |
Angle of pole |
1.82 |
rad |
Angle between pole axis and pole side |
.052 |
rad |
Maixmum field at pole edge |
0.9 |
T |
Maximum field inside yoke |
1.36 |
T |
Overall core - Height |
64.8 |
cm |
- Width |
70.0 |
cm |
- Length (Magnetic steel ONLY) |
21 |
cm |
Total mass of magnetic core |
243* |
kg |
Lamination thickness |
.15 |
cm |
Lamination stacking method |
Parallel |
Coil |
Conductor material |
Copper |
Conductor - Height |
.742 |
cm |
- Width |
.498 |
cm |
- Hole diameter |
.297 |
cm |
- Corner radius |
.13 |
cm |
Conductor min. bend radius (inside edge) |
- Height |
2.0 |
cm |
- Width |
1.9 |
cm |
Insulation - Tape - Thickness - Turn |
.0191 |
cm |
- Ground |
.0178 |
cm |
- Width - Turn |
2.5 |
cm |
- Ground |
2.5 |
cm |
Insulation total thickness - Turn |
.0191 |
cm |
- Ground |
.107 |
cm |
Allowance between layers of conductor |
.076 |
cm |
Allowance between rows of conductor |
.025 |
cm |
Average turn length |
66.4 |
cm |
Magnetic efficiency |
93.3 |
Ampere-turns per pole |
7443 |
At |
Number of layers of conductors per pole |
13 |
Number of conductors per layer per pole |
4 |
Effective number of turns per magnet |
252 |
Number of turns per cooling circuit |
42 |
Number parallel connected conductors per magnet |
1 |
Coil - Height |
11.26 |
cm |
- Width |
2.43 |
cm |
Electrical |
Stored energy |
435 |
J |
Total inductance |
28 |
mH |
Total coil resistance |
108 |
mW |
Maximum supply current |
177 |
A |
Voltage across magnet |
19.1 |
V |
Overall magnet - Height |
75.9 |
cm |
- Width |
71.1 |
cm |
- Length |
30.5 |
cm |
Total mass of an assembled magnet |
314* |
kg |
OPERATING PARAMETERS OF THE MAGNET SYSTEM:
Cooling circuit |
Coolant supply temperature |
32* |
C |
Coolant temperature gradient |
10.4 |
C |
Pressure gradient |
80 |
psi |
Coolant flow |
34.7 |
gpm |
Power losses |
Electrical losses in magnets |
949 |
kW |
Electrical power to operate coolant pumps |
17 |
kW |
SOME AUXILIARY PARAMETERS FOR THIS DESIGN ARE:
Inside radius of core |
20.6 |
cm |
Cross-sectional area of core |
1605* |
cm2 |
Cross-sectional area of conductor |
.29 |
cm2 |
Current density in conductor |
620 |
A/cm2 |
Current density in coil |
336 |
A/cm2 |
Reynold's number |
8005 |
Coolant flow velocity |
188 |
cm/s |
Maximum conductor temperature |
42.8 |
°C |
*Calculated from computer model
