1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Subject: RE: Representing stateless device commands?
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Feister, Scott" <scott.feister at csuci.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Sat, 6 Jan 2024 20:26:20 +0000
Hi Scott,
  • My approach right now is to call them binary outputs (bo) records, e.g. a bo record named “MYLED:IncreaseBrightness” and then just ignore the PV value itself. Then I do “caput MYLED:IncreaseBrightness 1” every time I want to increase brightness. Is that a reasonable approach?
Yes, this is exactly what is typically done.  In fact, I was about to respond to your post from yesterday where you asked about how to set the value of the bo record back to 0.  I was going to say that in that case the value of the bo record is not important.  You are not sending the value in the protocol, and you are probably not displaying the value in an OPI screen.  You are using the bo record is as a “command” not a 2-value choice.  In that case you don’t care what the value is.  By writing either 0 or 1 to the VAL field, or by writing 1 to the .PROC file you will force the record to process, and hence send the command to the device.  There is no need to set the value back to 0 when the command is complete.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Feister, Scott via Tech-talk
Sent: Friday, January 5, 2024 12:48 PM
To: tech-talk at aps.anl.gov
Subject: Representing stateless device commands?
Hi EPICS community,
I searched the tech-talk forums and documentation for this answer for a long time, because I am confident it’s in there somewhere if I could just search the correct words. However, after a long search, I decided I would stop and ask the forum.
How can I represent a command to a device (using StreamDevice) for a command that does not involve a process variable?
For example, let’s say I have a device that has a single LED. It may accept two commands over RS232 such as:
DecreaseBrightness
IncreaseBrightness
ToggleOnOff
Since these commands operate on internal states to the device rather than states we as the user can access, we don’t actually have a PV state accessible directly to put into an EPICS PV. We just want to call those methods remotely from EPICS.
How can I basically send the above commands like I would in a Serial Terminal, but with EPICS?
Thanks!
Scott
Representing stateless device commands? Feister, Scott via Tech-talk
Prev: RE: [EXTERNAL] Representing stateless device commands? Feister, Scott via Tech-talk
Next: Re: Behavior of the soft motor's DINP field Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Next: Re: StreamDevice+regex for escaping and unescaping HEX messages Sebastian Eckert via Tech-talk
ANJ, 08 Jan 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
