1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Subject: Representing stateless device commands?
From: "Feister, Scott via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 5 Jan 2024 18:47:33 +0000
Hi EPICS community,
I searched the tech-talk forums and documentation for this answer for a long time, because I am confident it’s in there somewhere if I could just search the correct words. However, after a long search, I decided I would stop and ask the forum.
How can I represent a command to a device (using StreamDevice) for a command that does not involve a process variable?
For example, let’s say I have a device that has a single LED. It may accept two commands over RS232 such as:
DecreaseBrightness
IncreaseBrightness
ToggleOnOff
Since these commands operate on internal states to the device rather than states we as the user can access, we don’t actually have a PV state accessible directly to put into an EPICS PV. We just want to call those methods remotely from EPICS.
How can I basically send the above commands like I would in a Serial Terminal, but with EPICS?
My approach right now is to call them binary outputs (bo) records, e.g. a bo record named “MYLED:IncreaseBrightness” and then just ignore the PV value itself. Then I do “caput MYLED:IncreaseBrightness 1” every time I want to increase brightness. Is that a reasonable approach?
Thanks!
Scott
Re: [EXTERNAL] Representing stateless device commands? Hartman, Steven via Tech-talk
RE: Representing stateless device commands? Mark Rivers via Tech-talk
Prev: Re: LabCA for MATLAB Installation error boj via Tech-talk
Next: Re: [EXTERNAL] Representing stateless device commands? Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Prev: MVME6100 Fernando Ortiz via Tech-talk
ANJ, 06 Jan 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
