1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Subject: CS-Studio (Phoebus) Dynamic Population of PVs in GUI
From: "Manoussakis, Adamandios via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 14 Jan 2021 22:28:34 +0000
Hello All,
I was curious what the best way to go about populating our GUIs in CS Studio when we are dealing with multiple PVs that share a common attributes.  Such as
Device1:Subdevice1:Signal1
Device1:Subdevice1:Signal2
Device1:Subdevice2:Signal1
Device1:Subdevice2:Signal2
And so forth for N devices M Subdevices Z Signals
I was thinking to use macros that pull from drop down menus which would then populate the correct PVs for say specific waveforms.
Dropdown menu to select Device #, Dropdown menu to select subdevice # and then populate the PV waveforms for the correct subset I selected.
I only just started to use CS Studio and I think this seems possible but wasn’t completely sure.  I also saw that I could write some python scripting and have it run in CS Studio to parse out and place the correct PVs depending on drop down selections but wanted to check in first and see how people have been using it.
Thanks
RE: CS-Studio (Phoebus) Dynamic Population of PVs in GUI Pearson, Matthew R. via Tech-talk
Re: CS-Studio (Phoebus) Dynamic Population of PVs in GUI Michael Davidsaver via Tech-talk
Prev: Re: Error building asyn-R4-41 on Manjaro Wlodek, Jakub via Tech-talk
Next: RE: CS-Studio (Phoebus) Dynamic Population of PVs in GUI Pearson, Matthew R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
ANJ, 15 Jan 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
