1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Subject: Re: Error building asyn-R4-41 on Manjaro
From: "Wlodek, Jakub via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, David Vine <dvine at sigray.com>
Date: Thu, 14 Jan 2021 20:44:12 +0000
Hi David,
I believe to enable TIRPC builds with asyn, you need to uncomment the following line in asyn/configure/CONFIG_SITE:
Best Regards,
Jakub
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of David Vine via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, January 14, 2021 3:35 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Error building asyn-R4-41 on Manjaro
Hi all,
when building asyn4-41 (base 3.15.7) i got the error it couldn't find rpc.h. Some googling tells me that rpc is no longer provided by glibc but is in the tirpc package.
How do add tirpc (/usr/include/tirpc) to the include and linker when building asyn?
Thanks!
David
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API  -D_X86_64_ -DUNIX  -Dlinux     -O3   -Wall    -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC  -mtune=generic    -m64 -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../
asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/opt/epics/synApps/support/ipac-2-16/include   -I/opt/epi
cs/synApps/support/seq-2-2-8/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../../asyn/asynRecord/drvAsyn.c
cs/synApps/support/seq-2-2-8/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c vxi11core_xdr.c
vxi11core_xdr.c: In function ‘xdr_Device_Link’:
vxi11core_xdr.c:11:20: warning: unused variable ‘buf’ [-Wunused-variable]
  11 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_AddrFamily’:
vxi11core_xdr.c:21:20: warning: unused variable ‘buf’ [-Wunused-variable]
  21 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_Flags’:
vxi11core_xdr.c:31:20: warning: unused variable ‘buf’ [-Wunused-variable]
  31 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_ErrorCode’:
vxi11core_xdr.c:41:20: warning: unused variable ‘buf’ [-Wunused-variable]
  41 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_Error’:
vxi11core_xdr.c:51:20: warning: unused variable ‘buf’ [-Wunused-variable]
  51 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Create_LinkResp’:
vxi11core_xdr.c:116:20: warning: unused variable ‘buf’ [-Wunused-variable]
 116 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_WriteParms’:
vxi11core_xdr.c:132:20: warning: unused variable ‘buf’ [-Wunused-variable]
 132 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_WriteResp’:
vxi11core_xdr.c:150:20: warning: unused variable ‘buf’ [-Wunused-variable]
 150 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_ReadResp’:
vxi11core_xdr.c:229:20: warning: unused variable ‘buf’ [-Wunused-variable]
 229 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_ReadStbResp’:
vxi11core_xdr.c:243:20: warning: unused variable ‘buf’ [-Wunused-variable]
 243 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_GenericParms’:
vxi11core_xdr.c:255:20: warning: unused variable ‘buf’ [-Wunused-variable]
 255 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_EnableSrqParms’:
vxi11core_xdr.c:334:20: warning: unused variable ‘buf’ [-Wunused-variable]
 334 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_LockParms’:
vxi11core_xdr.c:348:20: warning: unused variable ‘buf’ [-Wunused-variable]
 348 |  register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_DocmdResp’:
vxi11core_xdr.c:445:20: warning: unused variable ‘buf’ [-Wunused-variable]
 445 |  register int32_t *buf;
cs/synApps/support/seq-2-2-8/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../../asyn/vxi11/drvVxi11.c
cs/synApps/support/seq-2-2-8/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../../asyn/vxi11/E5810Reboot.c
cs/synApps/support/seq-2-2-8/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../../asyn/vxi11/E2050Reboot.c
cs/synApps/support/seq-2-2-8/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../../asyn/vxi11/TDS3000Reboot.c
cs/synApps/support/seq-2-2-8/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../../asyn/devGpib/devCommonGpib.c
../../asyn/devGpib/devCommonGpib.c: In function ‘devGpib_initBi’:
../../asyn/devGpib/devCommonGpib.c:208:13: warning: strncpy’ specified bound 26 equals destination size [-Wstringop-truncation]
 208 |             strncpy(pbi->znam, pdevGpibNames->item[0], sizeof(pbi->znam));
../../asyn/devGpib/devCommonGpib.c:210:13: warning: strncpy’ specified bound 26 equals destination size [-Wstringop-truncation]
 210 |             strncpy(pbi->onam, pdevGpibNames->item[1], sizeof(pbi->onam));
../../asyn/devGpib/devCommonGpib.c: In function ‘devGpib_initBo’:
../../asyn/devGpib/devCommonGpib.c:312:17: warning: strncpy’ specified bound 26 equals destination size [-Wstringop-truncation]
 312 |                 strncpy(pbo->znam, papname[0], sizeof(pbo->znam));
../../asyn/devGpib/devCommonGpib.c:314:17: warning: strncpy’ specified bound 26 equals destination size [-Wstringop-truncation]
 314 |                 strncpy(pbo->onam, papname[1], sizeof(pbo->onam));
../../asyn/devGpib/devCommonGpib.c:326:13: warning: strncpy’ specified bound 26 equals destination size [-Wstringop-truncation]
 326 |             strncpy(pbo->znam, pdevGpibNames->item[0], sizeof(pbo->znam));
../../asyn/devGpib/devCommonGpib.c:328:13: warning: strncpy’ specified bound 26 equals destination size [-Wstringop-truncation]
 328 |             strncpy(pbo->onam, pdevGpibNames->item[1], sizeof(pbo->onam));
cs/synApps/support/seq-2-2-8/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../../asyn/devGpib/devSupportGpib.c
cs/synApps/support/seq-2-2-8/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../../asyn/devGpib/boSRQonOff.c
/usr/bin/ar -rc    libasyn.a        asynManager.o epicsInterruptibleSyscall.o asynGpib.o drvAsynSerialPort.o drvAsynIPPort.o drvAsynIPServerPort.o asynInt32Base.o asynInt32SyncIO.o asynInt64Base.o asynInt64SyncIO.o asynInt8ArrayBase.o asynInt8ArraySyncIO.o asynInt16ArrayBase.o asynInt16ArraySyncIO.o asynInt32ArrayBase.o asynInt32ArraySyncIO.o asynInt64ArrayBase.o asynInt64ArraySyncIO.o asynUInt32DigitalBase.o asynUInt32Dig
italSyncIO.o asynFloat64Base.o asynFloat64SyncIO.o asynFloat32ArrayBase.o asynFloat32ArraySyncIO.o asynFloat64ArrayBase.o asynFloat64ArraySyncIO.o asynOctetBase.o asynOctetSyncIO.o asynGenericPointerBase.o asynGenericPointerSyncIO.o asynEnumBase.o asynEnumSyncIO.o asynCommonSyncIO.o asynOptionSyncIO.o asynStandardInterfacesBase.o asynShellCommands.o asynInterposeCom.o asynInterposeEos.o asynInterposeFlush.o asynInterposeDe
lay.o asynInterposeEcho.o ParamListInvalidIndex.o ParamListParamNotFound.o ParamValNotDefined.o ParamValStringSizeRequestTooBig.o ParamValWrongType.o ParamValValueNotChanged.o paramVal.o asynPortDriver.o asynPortClient.o devAsynOctet.o asynEpicsUtils.o devAsynInt32.o devAsynInt8Array.o devAsynInt16Array.o devAsynInt32Array.o devAsynInt32TimeSeries.o devAsynUInt32Digital.o devAsynFloat64.o devAsynFloat32Array.o devAsynFloat
64Array.o devAsynFloat64TimeSeries.o devAsynInt64.o asynRecord.o drvAsyn.o vxi11core_xdr.o drvVxi11.o E5810Reboot.o E2050Reboot.o TDS3000Reboot.o devCommonGpib.o devSupportGpib.o boSRQonOff.o
/usr/bin/ranlib libasyn.a
/usr/bin/g++ -o libasyn.so -shared -fPIC -Wl,-hlibasyn.so -L/opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64 -L/opt/epics/base-3.15.7/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64 -Wl,-rpath,/opt/epics/base-3.15.7/lib/linux-x86_64          -rdynamic -m64            asynManager.o epicsInterruptibleSyscall.o asynGpib.o drvAsynSerialPort.o drvAsynIPPort.o drvAsynIPServerPort.o asynIn
t32Base.o asynInt32SyncIO.o asynInt64Base.o asynInt64SyncIO.o asynInt8ArrayBase.o asynInt8ArraySyncIO.o asynInt16ArrayBase.o asynInt16ArraySyncIO.o asynInt32ArrayBase.o asynInt32ArraySyncIO.o asynInt64ArrayBase.o asynInt64ArraySyncIO.o asynUInt32DigitalBase.o asynUInt32DigitalSyncIO.o asynFloat64Base.o asynFloat64SyncIO.o asynFloat32ArrayBase.o asynFloat32ArraySyncIO.o asynFloat64ArrayBase.o asynFloat64ArraySyncIO.o asynOc
tetBase.o asynOctetSyncIO.o asynGenericPointerBase.o asynGenericPointerSyncIO.o asynEnumBase.o asynEnumSyncIO.o asynCommonSyncIO.o asynOptionSyncIO.o asynStandardInterfacesBase.o asynShellCommands.o asynInterposeCom.o asynInterposeEos.o asynInterposeFlush.o asynInterposeDelay.o asynInterposeEcho.o ParamListInvalidIndex.o ParamListParamNotFound.o ParamValNotDefined.o ParamValStringSizeRequestTooBig.o ParamValWrongType.o Par
amValValueNotChanged.o paramVal.o asynPortDriver.o asynPortClient.o devAsynOctet.o asynEpicsUtils.o devAsynInt32.o devAsynInt8Array.o devAsynInt16Array.o devAsynInt32Array.o devAsynInt32TimeSeries.o devAsynUInt32Digital.o devAsynFloat64.o devAsynFloat32Array.o devAsynFloat64Array.o devAsynFloat64TimeSeries.o devAsynInt64.o asynRecord.o drvAsyn.o vxi11core_xdr.o drvVxi11.o E5810Reboot.o E2050Reboot.o TDS3000Reboot.o devComm
onGpib.o devSupportGpib.o boSRQonOff.o    -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../lib/linux-x86_64/libasyn.so
Installing library ../../lib/linux-x86_64/libasyn.a
make[2]: Leaving directory '/opt/epics/synApps/support/asyn-R4-41/asyn/O.linux-x86_64'
make[1]: Leaving directory '/opt/epics/synApps/support/asyn-R4-41/asyn'
make -C asyn/asynPortDriver/unittest install
make[1]: Entering directory '/opt/epics/synApps/support/asyn-R4-41/asyn/asynPortDriver/unittest'
perl -CSD /opt/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
   T_A=linux-x86_64 install
make[2]: Entering directory '/opt/epics/synApps/support/asyn-R4-41/asyn/asynPortDriver/unittest/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux     -O3   -Wall    -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET  -mtune=generic    -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include      -I/opt/epics/synApps/support/ipac-2-16/include   -I/opt/epics/synApps/support/seq-2-2-8/include -I/opt/epics/base/include/co
mpiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -MM -MF asynPortDriverTest.d  ../asynPortDriverTest.cpp
mpiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../asynPortDriverTest.cpp
/usr/bin/g++ -o asynPortDriverTest  -L/opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64 -L/opt/epics/base-3.15.7/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64 -Wl,-rpath,/opt/epics/base-3.15.7/lib/linux-x86_64          -rdynamic -m64            asynPortDriverTest.o    -lasyn -ldbRecStd -ldbCore -lca -lCom
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_bytes'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_free'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `clnt_sperror'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_bool'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_int'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `clnt_spcreateerror'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_string'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_void'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_enum'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `clnttcp_create'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_char'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_int'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_short'
/usr/bin/ld: /opt/epics/synApps/support/asyn-R4-41/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_char'
collect2: error: ld returned 1 exit status
make[2]: *** [/opt/epics/base/configure/RULES_BUILD:204: asynPortDriverTest] Error 1
make[2]: Leaving directory '/opt/epics/synApps/support/asyn-R4-41/asyn/asynPortDriver/unittest/O.linux-x86_64'
make[1]: *** [/opt/epics/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/opt/epics/synApps/support/asyn-R4-41/asyn/asynPortDriver/unittest'
make: *** [/opt/epics/base/configure/RULES_DIRS:84: asyn/asynPortDriver/unittest.install] Error 2
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Error building asyn-R4-41 on Manjaro David Vine via Tech-talk
Prev: Error building asyn-R4-41 on Manjaro David Vine via Tech-talk
Next: CS-Studio (Phoebus) Dynamic Population of PVs in GUI Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
ANJ, 14 Jan 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
