Pavel,
Once we have the isolated +/- 10 volt signal from the CTD (two for
redundancy) we connect to a signal conditioner and finally to ADC's .
Our power supply controls and protection systems are not EPICS, but
real-time Linux (redHawk from Concurrent). We use the LKCO to measure
magnet current for NSTX, our fusion device.
To measure high voltage, we have used the resistor-divider technique
you mention (special HV resistors) to get a measurement down to 10
volt range for conventional ADC.
We also use PPPL-designed point-point fiber optic links for analog
signals (ADC - serial/digital on fiber - DAC).
-ps
On Thu, Jan 31, 2013 at 1:48 AM, Pavel Maslov <[email protected]> wrote:
> Hi Paul,
> Thanks for the information. We'll check the LKCO out, it might be a good
> alternative to the NXCT.
> But I am more interested in how you have embedded it in your control system.
> Or is it just hooked to the oscilloscope so you catch a single pulse? Just
> out of curiosity, what kind of experiments do you perform with this sensor?
> Any ideas on the voltage transducer? How do you measure high-voltage at
> Princeton?
> Best regards,
> Pavel Maslov, MS
> Controls Engineer at Pulsed power Lab
> Efremov Institute for Electro-Physical Apparatus
> St. Petersburg, Russia
> Mobile: +7 (951) 672 22 19
> Landline: +7 (812) 461 01 01
- Re: Analog data acquisition in an EMI environment Pavel Maslov
- Analog data acquisition in an EMI environment Pavel Maslov
- Re: Analog data acquisition in an EMI environment Paul Sichta
Java, CAJ, DNS RE: CSS addr_list bug Kasemir, Kay
<2013>
<2013>
