I am working on running rtems on the altera nios2. I tested network-4-10-demos. The netdemo example was working. Now I am trying to test tftpClient exmaple. My host is RHEL5. The following is the message though I slightly modified the original program init.c nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB 6-1]", device 1, instance 1 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Free space 66115176 bootpc_init: using network interface 'tse0' boSotpc hw address is 0:7:ed:ff:49:0 My ip address is 128 .165 .32 .154 Domain Name Server is 128 .165 .1 .1 Time Server is 128 .165 .1 .1 Ignoring BOOTP/DHCP option code 44 Domain name is lanl.gov Subnet mask is 255 .255 .255 .0 Server ip address is 128 .165 .32 .156 Gateway ip address is 0 .0 .0 .0 Log server ip address is 128 .165 .32 .156 bootpc_Nadjust_interface: add net route, error=114 Destination Gateway/Mask/Hw Flags Refs Use Expire Interface 128.165.32.0 255.255 niitn et.255.0 U 0 0 9 tse0 TFTP mounted successfully ~~~~~~~! host path is ------->: /TFTP/128.165.32.156/mytftp/test.txt !!!! TFTP remote FILE SYSTEM initialization OK !!!!! fp is ((null)), and errno is 12 Open failed: Not enough space Please help me.
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
