YEah you have to use a null-modem cable to be able to talk to your device via RS232
On Fri, Jun 29, 2012 at 11:15 AM, Jack <[email protected]> wrote:
If the checksum and setup are rights,
did you try to cross the serial to Moxa cable ?
Hope this helps
-Mauro
Mauro Giacchini
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
V.le dell'Universita', 2
35020 LEGNARO (PD) - ITALY
Tel./Fax. +39.049.8068558
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
...the first EPICS installation to the project SPES realized from the
scratch in ITALY is in production since begin 2010!!
On 6/29/2012 1:51 AM, Scott Baily wrote:
We're trying to control a Gamma ion multi-pump controller via ethernet from a soft ioc. The problem is that we can't get any response from the controller. We're using a stream device protocol file that previous worked for an RS232 gamma ion pump controller. Although I have also not been able to get any response by telnetting directly to the port and attempting to issue commands.
This device uses a checksum, so the problem could be that the checksum is incorrect or some other problem such as the configuration of the MOXA serial to ethernet card that's internal to the device. It appears that I've configured the bit rate, parity, and stop bits to match the devices settings. What else should I be checking? perhaps the response is just not being transmitted over ethernet and I should configure data packing? or something else.
-- Best regards,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
- ethernet-based Gamma ion pump controller (mpc) Scott Baily
- Re: ethernet-based Gamma ion pump controller (mpc) Jack
Re: caget limitation retreiving ENUM list Dirk Zimoch
<2012>
Re: ethernet-based Gamma ion pump controller (mpc) Scott Baily
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
