High-Pressure Interest Group - High Pressure Neutron Scattering at the Spallation Neutron Source
Location
Virtual
Speaker
Dr. Bianca Haber, Oak Ridge National Laboratory
Start Date
11-20-2023
Start Time
1:00 p.m.
Description
Abstract:
In situ high pressure neutron scattering is very useful for the characterization of materials and their behaviors under extreme conditions. Neutron diffraction can be used to determine elemental stoichiometries and atomic positions of light elements and can also be used to directly determine magnetic structures. Neutron spectroscopy can measure dynamics and can, for example, determine phonon dispersions or phonon density of states. Exploiting these capabilities for in situ high pressure studies has, however, previously been limited in maximum pressures due to large sample volumes required. Recent developments at the Spallation Neutron Source (SNS) aim to overcome these limitations and I will highlight several ongoing developments here.
Neutron scattering is widely used to probe the phase behavior of quantum materials under ultralow temperature (ULT) conditions down. Combining ULT conditions with high pressure has in the past been mainly limited to the use of piston-cylinder type cells (so-called clamped cells) that are limited to ~2 GPa in pressure. At the SNS we are addressing this pressure limit through coupling a large-volume neutron diamond anvil cell (DAC) equipped with polycrystalline anvils [1] with a dilution refrigerator. Here, I will detail in situ neutron diffraction experiments on Yb2O3 conducted at 6 GPa and 170 mK on SNS’s SNAP high pressure diffractometer.  MORE…
For more information about her work, see: https://www.ornl.gov/staff-profile/bianca-haberl
Join ZoomGov Meeting: https://argonne.zoomgov.com/my/hpcat?pwd=bThydTZLaVlyaER1U3JrRXRqM2l6QT…
Meeting ID: 161 4046 1760
Passcode: 1760
One tap mobile
+16692545252,,16140461760# US (San Jose)
+16468287666,,16140461760# US (New York)
Or Find your local number: https://argonne.zoomgov.com/u/ad7OPqE86v
To report an event that is not listed, please contact webmaster, for additional synchrotron-related conferences, check lightsources.org.
