CAMERA Seminar - The Multi-Tiered Iterative Projection Framework: How to exploit the mathematical structure of inverse problems to reconstruct complex structure from challenging experimental data
Type Of Event
Seminar
Location
Virtual
Speaker
Jeffrey Donatelli, CAMERA, Lawrence Berkeley National Laboratory
Host
Nicholas Schwarz
Start Date
01-31-2023
Start Time
12:00 p.m.
Description
Abstract:
New experimental technologies have the potential to capture information from important biological objects and new materials at unprecedented detail and scales. However, the accelerating size, rate, complexity, and sensitivity of these new measurements are far outpacing the capability of traditional inversion methods to efficiently and robustly reconstruct the desired information from the data. In this talk, I will present a new general mathematical framework capable of overcoming many of these challenges in inversion. This framework, called Multi- Tiered Iterative Projections (M-TIP), is based on exploiting the mathematical structure of the inverse problem via an iterative application of projection operators that optimally target the physics of the experiment to maximize speed, accuracy, and robustness. I will demonstrate the use of M-TIP in solving important open problems in inversion from fluctuation scattering, single-particle diffraction, coherent surface scattering imaging, multiple-scattering electron crystallography, and more.
Link: https://lbnl.zoom.us/j/97289887292
01.30.2023
To report an event that is not listed, please contact webmaster, for additional synchrotron-related conferences, check lightsources.org.
