Investigation of Porous Materials for Sorption and Energy Conversion Applications Using in Situ X-ray Methods
Type Of Event
Presentation
Sponsoring Division
XSD
Location
Virtual
Speaker
Amani M. Ebrahim, SSRL/SLAC
Host
George Sterbinsky
Start Date
01-14-2022
Start Time
1:00 p.m.
Description
Abstract:
The application of synchrotron studies provides an in-depth fundamental understanding of the chemistry at the solid-multi-gas interface which in turn can provide the atomistic details necessary for material design to develop technologies for energy storage and conversion, decontamination, or defense. The utilization of in situ synchrotron capabilities enables the study of materials surface chemistry which probe the changes in catalysts and sorption materials while also correlating to the chemistry in real time. Metal Organic Frameworks (MOFs) are remarkable porous materials with intricate designs and connectivity and have high performance in catalytic transformation applications and materials for the destruction of chemical warfare agents (CWA). Understanding the role of reactive MOF catalysts and adsorbents in the decontamination of chemical warfare agents and in heterogenous catalysis (mild temperatures) is necessary to optimize material properties, thereby promoting favorable interactions between adsorbent and adsorbate molecules for optimal decontamination, defense and performance. Metal supported nanocatalysts are equally promising catalyst with stability for thermally enabled catalytic transformation. This presentation will describe three research thrusts aimed at using porous, high surface area materials such as monometallic or bimetallic MOFs for CWA decontamination technologies and (Pt, Mo, and Ru) metal supported catalysts for C-C bond activation respectively with the focus on using a multimodal scattering and spectroscopic approach to study the behavior of these complex materials under different environments. This in situ approach is crucial to understanding the working mechanism of materials under dynamic relevant conditions.
Microsoft Teams meeting
Join on your computer or mobile app
Click here to join the meeting
Or call in (audio only)
+1 630-556-7958,,465108064#   United States, Big Rock
Phone Conference ID: 465 108 064#
01.10.2022
To report an event that is not listed, please contact webmaster, for additional synchrotron-related conferences, check lightsources.org.
