Beams and Applications Seminar Series: Femtosecond laser-based measurements of THz pulses and relativistic electron bunch shapes at record acquisition rate and sub-picosecond resolution
Type Of Event
Seminar
Sponsoring Division
APS
Location
Virtual
Speaker
Eléonore Roussel, University of Lille
Host
Philippe Piot, ANL/NIU
Start Date
01-14-2021
Start Time
9:00 a.m.
Description
Join on BlueJeans: https://bluejeans.com/179807379
ABSTRACT
The latest-generation light sources, such as Free-Electron Lasers and fourth-generation synchrotron radiation facilities, require challenging ultrafast  optical measurements. In particular, there is generally a strong need for characterizing relativistic electron bunch shapes with sub-picosecond to femtosecond resolution. A particularly promising method relies on ultrafast measurement techniques based on the use of chirped laser pulses for probing the electric field created by the electrons either in the near field (in the vicinity of the bunches) or in the far field (i.e. looking at the radiation emitted by the bunches). However, developing such electric-field-recording techniques presents important challenges, given the ultrafast timescales, the repetition rates (up to hundreds of MHz), as well as the need for single-shot characterization. We present here a new strategy allowing pulses to be recorded in single shot with picosecond resolution at megahertz acquisition rates. The method is based on a combination of the so-called photonic time-stretch data acquisition, allowing long record lengths and novel electro-optic sampling techniques. We will also present a promising strategy to overcome the current time-resolution limitation of the existing setup, which requires new ideas from the ultrafast measurements community.
01.07.2021
To report an event that is not listed, please contact webmaster, for additional synchrotron-related conferences, check lightsources.org.
