1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Subject: Re: Thorlabs MFF101 Motor Device Support
From: Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov>
To: Matt Shaw - STFC UKRI <matt.shaw at stfc.ac.uk>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 12 Jan 2024 10:31:06 -0600
Matt,
I have no experience with the MFF101, but I did a quick google search and found this github issue where multiple users of thorlabs_apt (a python wrapper for the vendor windows library) report the same problem with the MFF101:
  https://github.com/qpit/thorlabs_apt/issues/3
Do any errors occur when attempting to move in the direction that doesn't work?
Kevin
On 1/11/24 07:49, Matt Shaw - STFC UKRI via Tech-talk wrote:
Has anyone had any success interfacing with the Thorlabs MFF101.
I am trying to integrate with our control system using asyn and StreamDevice but the device is only moving in one direction.
Cheers,
Matt
Thorlabs MFF101 Motor Device Support Matt Shaw - STFC UKRI via Tech-talk
Prev: triggerPV Object in Phoebus Antonio Miguel Lopez via Tech-talk
Next: Inquiry Regarding EPICS Support for Keysight 34470A Digital Multimeter Wenzhao Wei via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Prev: Thorlabs MFF101 Motor Device Support Matt Shaw - STFC UKRI via Tech-talk
Next: S7PLC drivers PSI documentation SAINTIN Katy via Tech-talk
ANJ, 12 Jan 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
