1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Subject: Re: s7nodave-3.0.2 compilation error
From: Vishnu Patel via Tech-talk <tech-talk at aps.anl.gov>
To: Freddie Akeroyd - STFC UKRI <freddie.akeroyd at stfc.ac.uk>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 12 Jan 2024 10:03:11 +0000
Thanks Freddie,
     It s7nodave 3.0.2 works fine with visual studio , windows 10.
Thanks & REgards
Vishnu
Sent from Outlook
From: Freddie Akeroyd - STFC UKRI <freddie.akeroyd at stfc.ac.uk>
Sent: 07 January 2024 23:25
To: Vishnu Patel <patel.vishnu at hotmail.com>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: s7nodave-3.0.2 compilation error
Hi Vishnu,
Glad to hear 3.0.2 from https://github.com/FreddieAkeroyd/s7nodave is working with Visual Studio -  I’ll see if I can push the changes upstream
Freddie
Sent: 05 January 2024 09:42
To: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>
Dear Freddie,
     Thanks for your support.
It is working fine for me now.
With best regards
Vishnu
Sent: 05 January 2024 00:21
Hi Vishnu,
I’ve updated https://github.com/FreddieAkeroyd/s7nodave  to 3.0.2 – does that work for you?
Freddie
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Freddie Akeroyd - STFC UKRI via Tech-talk
Sent: 04 January 2024 11:58
I did get a previous version (2.1.3) compiled under windows  https://github.com/FreddieAkeroyd/s7nodave - I expect there are similar windows compatibility issues in 3.0.2 I can probably take a look at some point in the next few days if you like, but you may be able to fix 3.0.2 just using the same changes I used for 2.1.3
Freddie
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Vishnu Patel via Tech-talk
Sent: 04 January 2024 11:11
To: Tech Talk (tech-talk at aps.anl.gov) <Tech-talk at aps.anl.gov>
Subject: s7nodave-3.0.2 compilation error
    I am getting s7nodave compilation error in windows 10
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251 -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -I../../../..//seq-2.2.5/include   -I../../../..//asyn4-37/include -IF:/Work/Project/base-7.0.6.1_vs2022/include/compiler/msvc -IF:/Work/Project/base-7.0.6.1_vs2022/include/os/WIN32 -IF:/Work/Project/base-7.0.6.1_vs2022/include        -c ../PlcAddress.cc
PlcAddress.cc
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251 -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -I../../../..//seq-2.2.5/include   -I../../../..//asyn4-37/include -IF:/Work/Project/base-7.0.6.1_vs2022/include/compiler/msvc -IF:/Work/Project/base-7.0.6.1_vs2022/include/os/WIN32 -IF:/Work/Project/base-7.0.6.1_vs2022/include        -c ../PollGroup.cc
PollGroup.cc
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251 -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -I../../../..//seq-2.2.5/include   -I../../../..//asyn4-37/include -IF:/Work/Project/base-7.0.6.1_vs2022/include/compiler/msvc -IF:/Work/Project/base-7.0.6.1_vs2022/include/os/WIN32 -IF:/Work/Project/base-7.0.6.1_vs2022/include        -c ../PortDriver.cc
PortDriver.cc
F:\Work\Project\base-7.0.6.1_vs2022\modules\s7nodave-3.0.2\s7nodaveApp\src\PortDriver.cc(4): fatal error C1083: Cannot open include file: 'netdb.h': No such file or directory
make[3]: *** [F:/Work/Project/base-7.0.6.1_vs2022/configure/RULES_BUILD:263: PortDriver.obj] Error 2
make[3]: Leaving directory 'F:/Work/Project/base-7.0.6.1_vs2022/modules/s7nodave-3.0.2/s7nodaveApp/src/O.windows-x64'
make[2]: *** [F:/Work/Project/base-7.0.6.1_vs2022/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[2]: Leaving directory 'F:/Work/Project/base-7.0.6.1_vs2022/modules/s7nodave-3.0.2/s7nodaveApp/src'
make[1]: *** [F:/Work/Project/base-7.0.6.1_vs2022/configure/RULES_DIRS:85: src.install] Error 2
make[1]: Leaving directory 'F:/Work/Project/base-7.0.6.1_vs2022/modules/s7nodave-3.0.2/s7nodaveApp'
make: *** [F:/Work/Project/base-7.0.6.1_vs2022/configure/RULES_DIRS:85: s7nodaveApp.install] Error 2
F:\Work\Project\base-7.0.6.1_vs2022\modules\s7nodave-3.0.2>
how to resolve netdb.h error?
Thanks
Vishnu
s7nodave-3.0.2 compilation error Vishnu Patel via Tech-talk
RE: s7nodave-3.0.2 compilation error Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: S7PLC drivers PSI documentation Ralph Lange via Tech-talk
Next: triggerPV Object in Phoebus Antonio Miguel Lopez via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Prev: RE: s7nodave-3.0.2 compilation error Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Behavior of the soft motor's DINP field Abdalla Ahmad via Tech-talk
ANJ, 12 Jan 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
