Sent: Wednesday, January 10, 2024 10:31 AM
To: Henrique F. Simoes
Cc: tech-talk at aps.anl.gov
Subject: Re: GNU/Linux and GigE camera settings for high-throughput with ADAravis
> Hi Henrique,
> this throughput cannot be transported by an Ethernet with 1Gbit/s?
> 2952 x 1944 * 3 * 8 * 8 (bit) -> 1,101,828,096 bit/s
Thank you for this note! This can explain why packets get lost in my test
environment. For the sake of completeness, the 8.12 frames/s I described is the
maximum value the camera's firmware allows me to set. Any higher value is
clipped to that one. It turns out I didn't double check its throughput.
But still, the math does not match for 7.66Hz, the limit Mark Rivers
highlighted in his comment:
2952 x 1944 * 3 * 8 * 23 / 3 (bit) -> 1,055,918,592 bit/s
Unless we treat the limit as 1 Gigibit/s, which shouldn't be the case, right?
It should still be noted that Ethernet, IP, UDP and GVSP overhead for each
packet is not being taken into account.
> Gruss Heinz
> Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
> Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
> Faradayweg 4-6 | VC: https://zoom.fhi.berlin/junkes
> D - 14195 Berlin | E-Mail: junkes at fhi-berlin.mpg.de
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- GNU/Linux and GigE camera settings for high-throughput with ADAravis Henrique F. Simoes via Tech-talk
- Re: GNU/Linux and GigE camera settings for high-throughput with ADAravis Heinz Junkes via Tech-talk
S7PLC drivers PSI documentation SAINTIN Katy via Tech-talk
Re: GNU/Linux and GigE camera settings for high-throughput with ADAravis Henrique F. Simoes via Tech-talk
<2024>
Re: GNU/Linux and GigE camera settings for high-throughput with ADAravis Mark Rivers via Tech-talk
<2024>
