1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Subject: OPC UA build problem
From: LORIOT Vivien via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 10 Jan 2024 10:32:15 +0000
Dear community,
I’m trying to use the OPC UA epics-module driver available here : epics-modules/opcua: EPICS Device Support for OPC UA (github.com)
I was wondering if someone already got this problem during the Top building (I’ve installed the open62541 lib V1.3):
START :
c++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3   -Wall    -DEPICS_NO_CALLBACK -DHAS_XMLPARSER -std=c++11 -fdiagnostics-color=always -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../devOpcuaSup -I../../devOpcuaSup/open62541 -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include/compiler/gcc -I/nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include/os/Linux -I/nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include    -I../../devOpcuaSup/open62541 -I/usr/include/libxml2 -I/volatile/home/vl276037/Top/open62541-1.3.9/install/include    -c ../opcuaItemRecord.cpp
../opcuaItemRecord.cpp:186:6: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
  186 | rset opcuaItemRSET = {
In file included from /nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include/dbBase.h:22,
                 from /nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include/dbAccess.h:20,
                 from ../opcuaItemRecord.cpp:19:
/nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include/recSup.h:89:21: note: declared here
   89 | typedef struct rset rset EPICS_DEPRECATED;
../opcuaItemRecord.cpp:190:20: error: invalid conversion from ‘long int (*)(dbCommon*, int)’ to ‘long int (*)()’ [-fpermissive]
  190 |     RECSUPFUN_CAST(init_record),
      |                    long int (*)(dbCommon*, int)
../opcuaItemRecord.cpp:43:31: note: in definition of macro ‘RECSUPFUN_CAST’
   43 | #    define RECSUPFUN_CAST(F) F
END :
I’m using a Rocky Linux 9.2 system with a gcc 12.2.0 and an Epics Base V7.0.7.
Thanks for your consideration.
Vivien LORIOT
Ingénieur Contrôle/Commande
Laboratoire de Développement et d’Intégration des Systèmes de Contrôle
Commissariat à l’énergie atomique et aux énergies alternatives
CEA Paris-Saclay
DRF/IRFU/DIS/LDISC
Bâtiment 472 – Pièce 105
Tel : +33 1 69 08 95 17
Re: OPC UA build problem Ralph Lange via Tech-talk
Prev: RE: Behavior of the soft motor's DINP field Pearson, Matthew via Tech-talk
Next: GNU/Linux and GigE camera settings for high-throughput with ADAravis Henrique F. Simoes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Prev: Job Opportunities: Controls Software Engineers, STFC ISIS Facility, Oxfordshire, UK Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: OPC UA build problem Ralph Lange via Tech-talk
ANJ, 11 Jan 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
