Hi again,
Just to share that I could find the same behavior on a record on
mrfioc2. This one:
https://github.com/epics-modules/mrfioc2/blob/master/mrmShared/Db/databuftx.db#L2
https://github.com/epics-modules/mrfioc2/blob/master/mrmShared/src/devMrfBufTx.cpp#L171
If I try to create a similar softRecord it works as it should.
Cheers
On 1/9/24 08:03, Gabriel Fedel via Tech-talk wrote:
Hi tech-talk,
I am facing a strange issue with a device support for one aao record (or
waveform), on that implementation when I change the value of the record
the pvmonitor is not updated but the camonitor it is.
For example:
$ pvput TD-TEST:EvtCodes-SP
[6,7,8,9,10,11,12,13,15,18,19,96,97,100,101,102,103,120,127,60,61,62,63,64]
Old : 2024-01-09 07:53:23.819
[6,7,8,9,10,11,12,13,15,18,19,96,97,100,101,102,103,120,127,60,66,62,63,64]
New : 2024-01-09 07:53:46.770
$ pvmonitor TD-TEST:ScEvtCodes-SP
TD-TEST:ScEvtCodes-SP 2024-01-09 07:53:23.819
$ camonitor TD-TEST:ScEvtCodes-SP
TD-TEST:ScEvtCodes-SP 2024-01-09 07:53:23.818697 24 6 7 8 9 10 11 12 13
15 18 19 96 97 100 101 102 103 120 127 60 66 62 63 64
TD-TEST:ScEvtCodes-SP 2024-01-09 07:53:46.770254 24 6 7 8 9 10 11 12 13
15 18 19 96 97 100 101 102 103 120 127 60 61 62 63 64
I imagine I might be missing some piece of implementation of the device
support. Anyone has seen this before ? if someone has some simple
example of an aao device support implementation that could help also.
Thanks
Gabriel Fedel
Embedded Software Developer / Integrated Control System Division
European Spallation Source ERIC
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
- Help with device support for aao (waveform) Gabriel Fedel via Tech-talk
areaDetector monthly meeting Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
<2024>
<2024>
