On Fri, 2023-01-20 at 16:16 +0000, Leblanc, Gregory via Tech-talk wrote:
> Hi folks,
> I feel like I'm close to getting EPICS to talk to our Keysight measurement mainframes but can't quite get there. I don't see any errors when I start the IOC with st.cmd until after iocRun, at which point it reports :
> 2023/01/20 11:08:24.866492 LAN0 swag5testIDN: No reply within 1000 ms to "*IDN?"
> 2023/01/20 11:08:25.869293 LAN0 swag5testIDNwf: No reply within 1000 ms to "*IDN?"
> How do I get some more debugging messages? Maybe some capture of what it's sending? I think it's getting no response because asynReport 10 LAN0 shows:
> LAN0 multiDevice:No canBlock:Yes autoConnect:Yes
> enabled:Yes connected:Yes numberConnects 1
> nDevices 0 nQueued 0 blocked:No
> asynManagerLock:No synchronousLock:No
> exceptionActive:No exceptionUsers 12 exceptionNotifys 0
> traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
> interposeInterfaceList
> asynOctet pinterface 0x7fd4a97e7820 drvPvt 0xd13f40
> interfaceList
> asynCommon pinterface 0x7fd4a97e3e30 drvPvt 0xd106d0
> asynOption pinterface 0x7fd4a97e3e50 drvPvt 0xd106d0
> asynOctet pinterface 0xd107f0 drvPvt 0xd106d0
> Port 10.0.0.105:5025: Connected
> fd: 4
> Characters written: 10
> Characters read: 0
> I also did a basic test using telnet and got a reasonable response. Below I've added the output from running st.cmd.
You can get debug infos from asyn (asynTraceSomething), but you already got
some: "Characters read: 0" The device did not reply.
You may try to change your terminators.
Dirk
> #!../../bin/linux-x86_64/swag5test
> # Set up environment
> < envPaths
> epicsEnvSet("IOC","iocswag5test")
> epicsEnvSet("TOP","/home/leblanc/EPICS/TEST/swag5")
> epicsEnvSet("EPICS_BASE","/home/leblanc/EPICS/epics-base")
> epicsEnvSet("SUPPORT","/home/leblanc/EPICS/support")
> epicsEnvSet("ASYN","/home/leblanc/EPICS/support/asyn")
> epicsEnvSet("CALC","/home/leblanc/EPICS/support/calc")
> epicsEnvSet("STREAM","/home/leblanc/EPICS/support/StreamDevice")
> epicsEnvSet "STREAM_PROTOCOL_PATH" "/home/leblanc/EPICS/TEST/swag5/db"
> # Allow PV name prefixes and serial port name to be set from the environment
> epicsEnvSet "P" "swag5"
> epicsEnvSet "R" "test"
> epicsEnvSet "HOST" "192.168.1.111"
> epicsEnvSet "PORT" "5025"
> ## Register all support components
> cd "/home/leblanc/EPICS/TEST/swag5"
> dbLoadDatabase "dbd/swag5test.dbd"
> swag5test_registerRecordDeviceDriver pdbbase
> # Set up ASYN ports
> drvAsynIPPortConfigure("LAN0","10.0.0.105:5025",0,0,0)
> #1st argument is the port's name
> #2nd argument is the "IP address: port num"
> #3rd argument is priority; 0 means medium
> #4th argument is noAutoConnect; 0 means yes, autoconnect
> #5th argument is noProcessEOS; 0 means do not close connection on timeout, 1 means close it
> var streamError 1
> var streamDebug 1
> var streamDebugColored 1
> var streamErrorDeadTime 30
> var streamMsgTimeStamped 1
> streamSetLogfile("logfile.txt")
> ## Load record instances
> dbLoadRecords("db/devswag5.db","P=swag5,R=test,PORT=LAN0,A=0")
> ## Start EPICS
> cd "/home/leblanc/EPICS/TEST/swag5/iocBoot/iocswag5test"
> iocInit
> Starting iocInit
> ## EPICS R7.0.7.1-DEV
> ## Rev. R7.0.7-5-g0f8ea3aa3671cb0433b4
> ## Rev. Date Git: 2022-09-25 09:34:13 -0700
> iocRun: All initialization complete
> epics> 2023/01/20 11:08:24.866492 LAN0 swag5testIDN: No reply within 1000 ms to "*IDN?"
> Gregory Leblanc
> Accelerator Engineer
> Edwards Accelerator Lab - Ohio University
> 123 University Terrace
> Athens, OH 45701 USA
> leblanc at ohio.edu
> M: (401) 52-OUAL1 or (401) 526-8251
- RE: [External] Re: SCPI StreamDevice troubleshooting (Keysight 34980A via TCP) Leblanc, Gregory via Tech-talk
- RE: SCPI StreamDevice troubleshooting (Keysight 34980A via TCP) Mark Rivers via Tech-talk
- SCPI StreamDevice troubleshooting (Keysight 34980A via TCP) Leblanc, Gregory via Tech-talk
<2023>
<2023>
