1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: How to use epicsThreadSetCPUaffinity in epics 7.0.4
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 18 Jan 2023 10:21:01 +0100
Hi Daeyeong,
On Tue, 17 Jan 2023 at 20:10, Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov> wrote:
On 1/16/23 1:15 AM, 김대영 via Tech-talk wrote:
> How to use functions (epicsThreadSetCPUaffinity / epicsThreadSetPosixPriority) in epics 7.0.4?
> If the above functions are not available, is there an alternative?
Previously, epics 3.1.4 was used.
When I tried to change it to epics 7, the following problems occurred:
  > undefined reference to 'epicsThreadSetCPUaffinity '
 > undefined reference to 'epicsThreadSetPosixPriority '
The only reference I can find to those functions is in this 2011 email where they were requested by ITER, but they have never been included in EPICS Base itself. The EPICS community does have an external support module called MCoreUtils which provides utilities for running EPICS on multi-core systems, but I think you may need to consult with any contacts you might have with ITER and/or CosyLab to know how to convert your existing code.
I knew that sounded familiar...
Cosylab did an assessment of these things for ITER back in 2011, and I provided a slightly different and extended implementation in 2012/2013, which is the MCoreUtils [1] module that Andrew mentioned.
MCoreUtils is maintained and works with current EPICS versions. It provides the functionality you need (and more). It is also a regular system package in all supported releases of ITER's CODAC Core System distribution.
Cheers,
~Ralph
How to use epicsThreadSetCPUaffinity in epics 7.0.4 김대영 via Tech-talk
Re: How to use epicsThreadSetCPUaffinity in epics 7.0.4 Andrew Johnson via Tech-talk
Prev: Error in ADSimDetector (areaDetector) compilation Martín Marín Vilches via Tech-talk
Next: Re: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: How to use epicsThreadSetCPUaffinity in epics 7.0.4 Andrew Johnson via Tech-talk
Next: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Marco A. Barra Montevechi Filho via Tech-talk
ANJ, 18 Jan 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
