1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Weird behaviour in wait=True when using epics.Motor.get(something, something, wait=True)
From: Matt Newville via Tech-talk <tech-talk at aps.anl.gov>
To: "Marco A. Barra Montevechi Filho" <marco.filho at lnls.br>
Cc: SWC <swc at lnls.br>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 17 Jan 2023 12:57:22 -0600
Marco,
I have to admit I do not know for sure when a put to a Motor Record's CNEN field would take a lot of time. It seems odd to be changing a motor from closed- to open-loop control with any frequency at all, especially while also moving the motor and/or expecting positions to be reported well.  Wouldn't the idea of changing that setting mean that you expect the timing for a "put()" to be changing too?
That said, I would say that getting callbacks themselves should be fairly predictable.  But,  I would also suggest not mixing shell and Python for any timing work.  That will include the startup of Python and the initial connection of Epics PVs.  Those should not be slow, but it will involve network traffic so not completely determined.
I might suggest starting with something like this:
import epics
import time
def check_values(pvname, value, timestamp=0, **kwargs):
     print('callback for ', pvname, value, timestamp)
motor = epics.Motor('MGN:B:E873A:DIAG:X:m1')
# get the value of the CNEN field to make sure that PV/Channel is connected
cnen_val = motor.get('CNEN')
# with that connected, add the callback
motor._pvs['CNEN'].add_callback(check_value)
SLEEP_TIME = 0.1
for i in range(10):
     print('# Loop ', i)
     time.sleep(SLEEP_TIME)
     for cnen_val in (0, 1, 0, 1, 0, 1, 0, 1, 0, 1):
          motor.put('CNEN', cnen_val, wait=False)
print("LOOP DONE")
time.sleep(1)
or some variations from that.   Unless the SLEEP_TIME is way too fast for processing, I think you should get all the callbacks run.  Or, you could try using `wait=True` for that put.
On Tue, Jan 17, 2023 at 12:26 PM Marco A. Barra Montevechi Filho <marco.filho at lnls.br> wrote:
>However, if the motor record writes multiple values to a field (and does a callback) in rapid succession you are not guaranteed to receive callbacks for all of the values.
Im not sure if i understood this so i made some scripts to test. I made a script called test.py:
import epics, sys, time
desired_value = sys.argv[1]
def check_value(**kwargs):
    print("a")
a = epics.Motor("MGN:B:E873A:DIAG:X:m1")
b = epics.PV("MGN:B:E873A:DIAG:X:m1.CNEN")
b.add_callback(check_value)
a.put("CNEN",desired_value)
and in my terminal: for i in {0..50}; do echo "b"; ./test.py $((1-$a)); sleep 0.1; done
What i got was several "a"s and "b"s but with much more "b"s:
b
a
b
a
b
b
b
a
(etc...)
So i supposed this is not because im not getting the callback, but because my script is terminating before i have time to receive the callback and execute the check_value function. So i added sleep(0.1) after a.put("CNEN", desired_value) and now what i get when doing
is several "a"s and "b"s but now with more "a"s than "b"s:
b
a
a
b
a
a
(etc...)
So im guessing i not only have time to receive the callback but im also receiving two sometimes. Is this line way of reasoning correct?
Thanks in advance,
Marco
Sent: 17 January 2023 14:27
To: Marco A. Barra Montevechi Filho <marco.filho at lnls.br>; Matthew Newville <newville at cars.uchicago.edu>
Cc: SWC <swc at lnls.br>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; mooney at anl.gov <mooney at anl.gov>
Subject: Re: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True)
> Is this behavior the same with the callbacks (i mean at python level like the add_callback in the PV objects)? Is this why i sometimes get two, one or no callback from record in identical situations in a kinda unpredictable manner?
No, I don't think that should affect callbacks.  The motor record does callbacks even while it is moving.
However, if the motor record writes multiple values to a field (and does a callback) in rapid succession you are not guaranteed to receive callbacks for all of the values.  There is no queuing in the Channel Access server, so you are only guaranteed to get the last value of the field.  That can explain behavior where you sometimes get a callback on an intermediate value, and sometimes you don't.
From: Marco A. Barra Montevechi Filho <marco.filho at lnls.br>
Sent: Tuesday, January 17, 2023 11:20 AM
To: Mark Rivers <rivers at cars.uchicago.edu>; Matthew Newville <newville at cars.uchicago.edu>
That explains a lot!
If yes, what is the best way of checking the field (not the record) for updates?
The best i cant think is something like:
start_time=time.time()
while VALUE!=desired_value:
    VALUE=epics.caget(BLAH)
    time.sleep(0.1)
    if time.time()-start_time>timeout:
        raise SomeException
But this could considerably slow my scan. Is there a better way?
Marco
Sent: 17 January 2023 14:11
To: Matthew Newville <newville at cars.uchicago.edu>; Marco A. Barra Montevechi Filho <marco.filho at lnls.br>
Hi Marco,
I think there may be a complication with the motor record, and other complex records like mca, scaler, etc.  Using Python put(wait=True) means you are using ca_put_callback() in the underlying Channel Access C code.  ca_put_callback() completes when the record calls recGblFwdLink().  For those complex records recGblFwdLink() is called when the record is "done".  For the motor record that means that a move is complete, for the mca and scaler record it means acquisition is complete.  I think this means that if a move is in progress when writing to CNEN then that write will only complete when the move is complete, so it could take a long time.
Tim Mooney may correct me if my understanding is wrong.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, January 17, 2023 10:53 AM
Thanks, Matt.
In my tests, put("CNEN",value,wait=True) returns in much less than 10 seconds, so i dont think this is the case.
Something interesting: i had the same problem with VELO field so im guessing problem is with my understanding about how the IOC works in general, not an actual communication with hardware problem.
Best regards,
Marco
From: Matt Newville <newville at cars.uchicago.edu>
Sent: 17 January 2023 13:30
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; SWC <swc at lnls.br>
To follow up on Torsten's comment, the default timeout for a `epics.Motor.put()` is 10 seconds.   The behavior you are seeing could be because the processing of setting CNEN takes more than that 10 seconds.
Giving a longer timeout to the `put()` might clarify what is happening.
On Mon, Jan 16, 2023 at 3:27 PM Marco A. Barra Montevechi Filho via Tech-talk <tech-talk at aps.anl.gov> wrote:
Good evening all.
Im working with the same IOC i was using here: https://epics.anl.gov/tech-talk/2023/msg00020.php. Now i loaded some motor records in it and am trying to control the IOC via pyepics. Something weird is happening.
i made the following python script:
import epics
a.put("CNEN", 1,wait=True)
assert a.get("CNEN")==1
And i frequently get assertion errors. What is happening? Shouldn't wait=True prevent this? How do i debug this?
Even more weird: i tried debugging this with callbacks:
import epics, time
a = epics.Motor(
def printvalue(**kwargs):
    print(kwargs["value"])
b.add_callback(printvalue)
c = 1
while True:
    c=1-c
    print("#####")
    a.put("CNEN",c)
    time.sleep(0.1)
And i get prints like:
1
0
1
0
Why do i sometimes get two callbacks and sometimes get only one? Thanks in advance for any help.
I append the IOC initialization log and the substitutions file it loads:
INIT LOG:
#!/usr/local/epics/apps/pigcs2IOC/bin/linux-x86_64/pigcs2
< /usr/local/epics/apps/pigcs2IOC/iocBoot/iocPIGCS2/envPaths
epicsEnvSet("IOC","iocPIGCS2")
epicsEnvSet("TOP","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC")
epicsEnvSet("SUPPORT","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support")
epicsEnvSet("ASYN","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/asyn-R4-36")
epicsEnvSet("STREAM","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/StreamDevice-2-8-9")
epicsEnvSet("CALC","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/calc-R3-7-3")
epicsEnvSet("RECCASTER","/usr/local/epics-nfs/apps/recsync/1.4_epics_3.15/client")
epicsEnvSet("SNCSEQ","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/seq-2-2-6")
epicsEnvSet("BUSY","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/busy-R1-7-2")
epicsEnvSet("IPAC","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/ipac-2-15")
epicsEnvSet("MOTOR","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1")
epicsEnvSet("EPICS_BASE","/usr/local/epics-nfs/base/R3.15.6")
cd "/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC"
## Set up environment
epicsEnvSet("DEV","MGN:B:E873A:DIAG:X:")
epicsEnvSet("BL", "MGN:B:E873A:DIAG:X")
epicsEnvSet("IOCNAME", "MGN-B-E873A-DIAG-X")
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES",15728645)
# protocol file paths
epicsEnvSet ("STREAM_PROTOCOL_PATH", ".:/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/db")
dbLoadDatabase "dbd/pigcs2.dbd"
pigcs2_registerRecordDeviceDriver pdbbase
cd "/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC/iocBoot/iocPIGCS2"
## motorUtil (allstop & alldone)
dbLoadRecords("/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/db/motorUtil.db", "P=MGN:B:E873A:DIAG:X:")
# < PI_GCS2.cmd
# PI GCS2 support
dbLoadTemplate("/usr/local/epics/apps/config/PIGCS2/e873aX.substitutions")
drvAsynIPPortConfigure("E873_ETH","CDE5B3D.abtlus.org.br:50000",0,0,0)
# Turn on asyn trace
# asynSetTraceMask("E873_ETH",0,3)
# asynSetTraceIOMask("E873_ETH",0,1)
# PI_GCS2_CreateController(portName, asynPort, numAxes, priority, stackSize, movingPollingRate, idlePollingRate)
# # this is the final setup
# PI_GCS2_CreateController("E873", "E873_ETH", 1, 0, 0, 100, 1000)
# speedup debug
PI_GCS2_CreateController("E873", "E873_ETH", 1, 0, 0, 50, 1000)
2023/01/16 18:23:03.949 read from E873_ETH: (c)2016-2020 Physik Instrumente (PI) GmbH & Co. KG, E-873.1AT, 120040762, 03.033
PIasynAxis::PIasynAxis() 0: 1
----------------- axis num: 0 createCLParams() m_szAxisName: 1-------------------
# Turn off asyn trace
# asynSetTraceMask("E873_ETH",0,1)
# asynSetTraceIOMask("E873_ETH",0,0)
# Set end-of-string terminators (port, addr, terminator)
asynOctetSetInputEos("E873_ETH", 0, "\n")
asynOctetSetOutputEos("E873_ETH", 0, "\n")
dbLoadRecords("/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC/db/PI_Support.db","P=MGN:B:E873A:DIAG:X:,R=m1:,PORT=E873,ADDR=0,TIMEOUT=1")
# asyn record for troubleshooting
dbLoadRecords("/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/asyn-R4-36/db/asynRecord.db","P=MGN:B:E873A:DIAG:X:,R=asynEth,PORT=E873_ETH,ADDR=0,OMAX=256,IMAX=524288")
# RECSYNC
dbLoadRecords("/usr/local/epics-nfs/apps/recsync/1.4_epics_3.15/client/db/reccaster.db", "P=MGN:B:E873A:DIAG:X:REC:")
# protocol
#dbLoadRecords("$(MOTOR)/db/e873.db", "P=$(DEV),PORT=E873_ETH")
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Sep 27 2021
e873aX.substitutions FILE:
file "$(MOTOR)/motorApp/Db/asyn_motor.db"
pattern
{P,              M,     DTYP,       PORT, ADDR,      DESC,  EGU,  DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC,  DHLM,  DLLM,  INIT}
{MGN:B:E873A:DIAG:X:,  "m1",  "asynMotor",  "E873",    0,  "Motor 1", mm,  Pos,    1,    0,    .1,    0,      0,    0,   0.000001,  7,     5.0,   -5.0,  ""}
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
--Matt Newville <newville at cars.uchicago.edu> 630-327-7411
Re: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Marco A. Barra Montevechi Filho via Tech-talk
Re: Weird behaviour in wait=True when using epics.Motor.get(something, something, wait=True) Matt Newville via Tech-talk
Re: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Mark Rivers via Tech-talk
Prev: Re: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Mark Rivers via Tech-talk
Next: Re: How to use epicsThreadSetCPUaffinity in epics 7.0.4 Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Next: Re: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Marco A. Barra Montevechi Filho via Tech-talk
ANJ, 18 Jan 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
