1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: EPICS Base building for NI myRIO (arm linux)
From: Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
To: inari badillo <inari.badillo at ehu.es>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 17 Jan 2023 13:31:54 +0000
On 17/01/2023 08:15, inari badillo via Tech-talk wrote:
Hello all,
I am trying to install EPICS base 7 on a NI myRIO 1900 (ARM CortexA9) with Linux RT.
I am installing in the host itself.
At some point of the installation, I get the following error:
"../flex/ccl.c:147:37: error: too many arguments to function 'char* readable_form()'
             fputs( readable_form( i ), file );"
I'm afraid some library is missing, but I have no clue.
Any help is very welcome.
Could you check if building with the branch from this PR works? https://github.com/epics-base/epics-base/pull/323
I'm surprised your compiler is complaining about this, though. Can you share what version and what compiler options, if any, you're using?
Thanks in advance,
Inari Badillo
Inari Badillo Fdez.
Elektrizitate eta Elektronika saila
UPV/EHU
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
EPICS Base building for NI myRIO (arm linux) inari badillo via Tech-talk
Prev: EPICS Base building for NI myRIO (arm linux) inari badillo via Tech-talk
Next: EPICS Code-a-thon Collaboration Workshop - Registration Now Open Diamond Events via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Next: Re: EPICS Base building for NI myRIO (arm linux) Michael Davidsaver via Tech-talk
ANJ, 17 Jan 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
