Hej all.
I think that this behaviour is - what it is.
In theory, the motorRecord could behave as you (and me) whish,
in proactise there are too many applications depending on this frequent
callbacks.
So this commit:
<https://github.com/epics-modules/motor/commit/c970afbfe71521d1587c51b0c7f3a634b03f5833>
Had to be reverted later:
<https://github.com/epics-modules/motor/commit/0ef39053aac72d8718ef99d08164da1be0825370>
For your case, writing to CNEN and wait for the controller to have
the amplifier switched on: Is this what you want ?
On our systems this power-on can take 0.6 seconds (typically)
up to 6 seconds (on a heavy drive, doing a self test after coldstart).
And if the safety relay is off after a power-fail,
it will never turn on.
So yes, in principle we could change the motorRecord to do what we want:
Wait for the driver to report "amplifier on".
In practise we would need a time out.
And a way to configure it.
I am not sure if it ith worth the effort (to change the motorRecord)
or if a simple poller with a timout in python is easier to implement.
HTH
BR
/Torsten
On 1/16/23 22:26, Marco A. Barra Montevechi Filho via Tech-talk wrote:
Good evening all.
Im working with the same IOC i was using here:
https://epics.anl.gov/tech-talk/2023/msg00020.php
<https://epics.anl.gov/tech-talk/2023/msg00020.php>. Now i loaded some
motor records in it and am trying to control the IOC via pyepics.
Something weird is happening.
i made the following python script:
import epics
a = epics.Motor("MGN:B:E873A:DIAG:X:m1")
a.put("CNEN", 1,wait=True)
assert a.get("CNEN")==1
And i frequently get assertion errors. What is happening? Shouldn't
wait=True prevent this? How do i debug this?
Even more weird: i tried debugging this with callbacks:
import epics, time
a = epics.Motor(
defprintvalue(**kwargs):
print(kwargs["value"])
b = epics.PV("MGN:B:E873A:DIAG:X:m1.CNEN")
b.add_callback(printvalue)
c = 1
whileTrue:
c=1-c
print("#####")
a.put("CNEN",c)
time.sleep(0.1)
And i get prints like:
1
0
1
0
Why do i sometimes get two callbacks and sometimes get only one? Thanks
in advance for any help.
I append the IOC initialization log and the substitutions file it loads:
*INIT LOG:*
#!/usr/local/epics/apps/pigcs2IOC/bin/linux-x86_64/pigcs2
< /usr/local/epics/apps/pigcs2IOC/iocBoot/iocPIGCS2/envPaths
epicsEnvSet("IOC","iocPIGCS2")
epicsEnvSet("TOP","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC")
epicsEnvSet("SUPPORT","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support")
epicsEnvSet("ASYN","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/asyn-R4-36")
epicsEnvSet("STREAM","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/StreamDevice-2-8-9")
epicsEnvSet("CALC","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/calc-R3-7-3")
epicsEnvSet("RECCASTER","/usr/local/epics-nfs/apps/recsync/1.4_epics_3.15/client")
epicsEnvSet("SNCSEQ","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/seq-2-2-6")
epicsEnvSet("BUSY","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/busy-R1-7-2")
epicsEnvSet("IPAC","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/ipac-2-15")
epicsEnvSet("MOTOR","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1")
epicsEnvSet("EPICS_BASE","/usr/local/epics-nfs/base/R3.15.6")
cd
## Set up environment
epicsEnvSet("DEV","MGN:B:E873A:DIAG:X:")
epicsEnvSet("BL", "MGN:B:E873A:DIAG:X")
epicsEnvSet("IOCNAME", "MGN-B-E873A-DIAG-X")
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES",15728645)
# protocol file paths
epicsEnvSet ("STREAM_PROTOCOL_PATH",
".:/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/db")
dbLoadDatabase "dbd/pigcs2.dbd"
pigcs2_registerRecordDeviceDriver pdbbase
cd
"/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC/iocBoot/iocPIGCS2"
## motorUtil (allstop & alldone)
dbLoadRecords("/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/db/motorUtil.db", "P=MGN:B:E873A:DIAG:X:")
# < PI_GCS2.cmd
# PI GCS2 support
dbLoadTemplate("/usr/local/epics/apps/config/PIGCS2/e873aX.substitutions")
drvAsynIPPortConfigure("E873_ETH","CDE5B3D.abtlus.org.br:50000",0,0,0)
# Turn on asyn trace
# asynSetTraceMask("E873_ETH",0,3)
# asynSetTraceIOMask("E873_ETH",0,1)
# PI_GCS2_CreateController(portName, asynPort, numAxes, priority,
stackSize, movingPollingRate, idlePollingRate)
# # this is the final setup
# PI_GCS2_CreateController("E873", "E873_ETH", 1, 0, 0, 100, 1000)
# speedup debug
PI_GCS2_CreateController("E873", "E873_ETH", 1, 0, 0, 50, 1000)
2023/01/16 18:23:03.949 read from E873_ETH: (c)2016-2020 Physik
Instrumente (PI) GmbH & Co. KG, E-873.1AT, 120040762, 03.033
PIasynAxis::PIasynAxis() 0: 1
----------------- axis num: 0 createCLParams() m_szAxisName:
1-------------------
# Turn off asyn trace
# asynSetTraceMask("E873_ETH",0,1)
# asynSetTraceIOMask("E873_ETH",0,0)
# Set end-of-string terminators (port, addr, terminator)
asynOctetSetInputEos("E873_ETH", 0, "\n")
asynOctetSetOutputEos("E873_ETH", 0, "\n")
dbLoadRecords("/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC/db/PI_Support.db","P=MGN:B:E873A:DIAG:X:,R=m1:,PORT=E873,ADDR=0,TIMEOUT=1")
# asyn record for troubleshooting
dbLoadRecords("/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/asyn-R4-36/db/asynRecord.db","P=MGN:B:E873A:DIAG:X:,R=asynEth,PORT=E873_ETH,ADDR=0,OMAX=256,IMAX=524288")
# RECSYNC
dbLoadRecords("/usr/local/epics-nfs/apps/recsync/1.4_epics_3.15/client/db/reccaster.db", "P=MGN:B:E873A:DIAG:X:REC:")
# protocol
#dbLoadRecords("$(MOTOR)/db/e873.db", "P=$(DEV),PORT=E873_ETH")
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Sep 27 2021
*e873aX.substitutions FILE:*
file "$(MOTOR)/motorApp/Db/asyn_motor.db"
pattern
{P, M, DTYP, PORT, ADDR, DESC, EGU, DIR,
VELO, VBAS, ACCL, BDST, BVEL, BACC, MRES, PREC, DHLM, DLLM,
INIT}
{MGN:B:E873A:DIAG:X:, "m1", "asynMotor", "E873", 0, "Motor 1",
mm, Pos, 1, 0, .1, 0, 0, 0, 0.000001, 7,
5.0, -5.0, ""}
Aviso Legal: Esta mensagem e seus anexos podem conter informações
confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e
considere eventual consulta ao remetente antes de copiá-la, divulgá-la
ou distribuí-la. Se você recebeu esta mensagem por engano, por favor
avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential
and/or privileged information. Observe its content carefully and
consider possible querying to the sender before copying, disclosing or
distributing it. If you have received this email by mistake, please
notify the sender and delete it immediately.
- Re: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Marco A. Barra Montevechi Filho via Tech-talk
- Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Marco A. Barra Montevechi Filho via Tech-talk
EPICS Base building for NI myRIO (arm linux) inari badillo via Tech-talk
<2023>
<2023>
