I am trying to set up a PostgreSQL RDMS to work together with EPICS to
save some PV values. However, I am having doubts about how to do it,
since the process is not clear to me.
First of all, I installed EPICS and I downloaded Phoebus. Both are
running with no problem. In addition, I installed PostgreSQL. It seems
to work fine. Then, I tried to learn how to connect EPICS and
PostgreSQL, and I ended up reading Phoebus documentation about the RDB
Archive Engine, and that was the point when I did no understand what I
was doing.
https://control-system-studio.readthedocs.io/en/latest/services/archive-engine/doc/index.html
The document says that I need to download the archive engine from:
https://controlssoftware.sns.ornl.gov/css_phoebus
But I can't find any archive engine in that place.
In addition, I am confused about the rol of Phoebus in this problem. Why
do I need to set up any preference in the Phoebus configuration to use
the Archive Engine? Phoebus is just a software to create and to display
graphical screen to monitor/check the control system. If I run the
Archive Engine, that software will save PV values in the PostgreSQL
tables that I want. So, I don't understand the relationship between
Phoebus and the Archive Engine, since the documentation is in the CSS web.
Any help would be useful.
Regards.
Óscar
- RE: EPICS, PostgreSQL, Archive Engine: doubts about how to use them Abdalla Ahmad via Tech-talk
Re: areaDetector/ADPilatus Mark Rivers via Tech-talk
<2023>
RE: [External] Kniel Power Supply Leblanc, Gregory via Tech-talk
<2023>
ANJ, 12 Jan 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
