1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: asyn
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Sinclair, John" <sinclairjw at ornl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 10 Jan 2023 18:43:42 +0000
Hi John,
The file vxi11core_xdr.c is created a build-time using the "rpcgen" command.  That means the rpc package must be installed on your system.  On newer Linux systems like yours that is called tirpc.  You will need to edit asyn/configure/CONFIG_SITE to set TIRPC=YES.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Sinclair, John via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, January 10, 2023 12:31 PM
To: tech-talk <tech-talk at aps.anl.gov>
Subject: asyn
Hello all,
I'm trying to build asyn R4-43. The build fails with references to missing vxi11 components.
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration     -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC -DHAVE_DEVINT64  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/drvPrologixGPIB -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/home/controls/epics-7.0.6/base/include/compiler/gcc -I/home/controls/epics-7.0.6/base/include/os/Linux -I/home/controls/epics-7.0.6/base/include        -c ../../asyn/asynRecord/drvAsyn.c
make[2]: *** No rule to make target 'vxi11core_xdr.c', needed by 'vxi11core_xdr.o'.  Stop.
I'm building with epics 7.0.6.
I have defined only EPICS_BASE in configure/RELEASE.
gcc --version
gcc (GCC) 8.5.0 20210514 (Red Hat 8.5.0-15)
make --version
GNU Make 4.2.1
Any guidance?
John Sinclair
ORNL
asyn Sinclair, John via Tech-talk
Prev: asyn Sinclair, John via Tech-talk
Next: areaDetector/ADPilatus 鲍康文 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 11 Jan 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
