On 1/2/23 19:43, Andrew Johnson wrote:
On 1/2/23 3:53 PM, Hu, Yong via Tech-talk wrote:
Another (less important) use case is a script I
sometimes use to avoid developing OPI screens remotely.
Michael's question is thus a valid one. For a simple/naive implementation of this feature the answer might be that the channel name “det1:NELM.RTYP” would time out, and such field aliases just wouldn't support the capr.pl or pvtree applications at all in that case. That might be acceptable,
I think it is desirable to continue to support remote database
"crawling", although no necessarily with RTYP alone. Which has
obvious limitations in requiring a client to encode knowledge
about record types. An alternative which I occasionally think
about is adding another pseudo field which GETs a description of
the record type. eg. as a string (.dbd or some json) or
equivalent PVD structure.
but I would want to be shown that any implementation would not significantly increase the amount of work that the IOC's CA Search thread has to do.
Agreed. In both the positive and especially the negative case.
ANJ, 03 Jan 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
