1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: mrfioc2-PCI device Configuration
From: gjzhai--- via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Thu, 20 Jan 2022 21:52:33 +0800 (GMT+08:00)
Hello all
I am trying to get MRF MTCA-EVG-300 and MTCA-EVR-300U configured and working on Linux using mrfioc2. I found geographic address(bus:device.function) in /proc/bus/pci/devices. The information is as follows:
0800 10ee7011 10 df100000 0 0 0 0 0 0 80000 0 0 0 0 0 0 pci_mrfevg
0900 10ee7011 11 df000000 0 0 0 0 0 0 40000 0 0 0 0 0 0 pci_mrfevr
According to the above information, my st.cmd in the iocevrmrm folder is defined as follows:
mrmEvrSetupPCI("MTCAEVR","09:00.0")
mrmEvgSetupPCI("EVG",08,00,0)
But the following error occurs:
Notice: devPCIFindSpec() expect B:D.F in hex
Device MTCAEVR 9:0.0 slot=8
Using IRQ 17
Failed to open uio device for PCI device 0000:09:00.0: No such filleor directory
Can neither open resource file nor uio file of PCI device 0000:09:00.0 BAR 0
PCI error: Failed to map BAR 0
Error: invalid spec '08'
PCI Device not found
I use mrfioc2 2.3.0 . How deal with this problem?
Thank you for your time. I am looking forward to your reply.
RE: mrfioc2-PCI device Configuration GAGET Alexis via Tech-talk
Prev: RE: PerkinElmer Windows 10 Varex Driver Link Mark Rivers via Tech-talk
Next: RE: mrfioc2-PCI device Configuration GAGET Alexis via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Prev: RE: PerkinElmer Windows 10 Varex Driver Link Cale E Lewis via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
