I have a periodic scanned PV which I occasionally set. However, when I set it, I can’t read the updated value until the periodic scan happens. I would like the PV value to update as soon as it’s set. I thought that was what was supposed to happen with FLNK but it doesn’t seem to.
My db has:
record (ai, "$(P):current1")
field (DTYP, "stream")
field (INP, "@thorlab.proto getcurrentch(1) $(BUS)")
field (SCAN, "10 second")
record (ao, "$(P):setcurrent1")
field (OUT, "@thorlab.proto setcurrentch(1) $(BUS)")
field (FLNK, "$(P):current1.PROC")
field (SCAN, "Passive")
"caput setcurrent1 10" works but it takes whatever is left of the 10 second scan period before current1 changes.
“caput current1.PROC 1” immediately updates the value in current1.
I tried field (FLNK, "$(P):current1”) but that doesn’t process either.
What’s the trick for getting a periodic scan PV to process within a forward link? Or is there some other way I’m supposed to do this?
Thanks.
Randall
LBNL
- Re: FLNK doesn't process Hu, Yong via Tech-talk
Re: Sequencer - Compiling multiple source files together Ralph Lange via Tech-talk
<2022>
<2022>
