Hi
We tried area detector previously to control Basler cameras from Pylon and it was working. We revisited the setup again but with one problem which is we can’t set specific frame rate from the ADAravis.adl GUI, frame rate enable PV value
is No and does not change. The camera is running with maximum acquisition rate of 32 FPS but ImageJ viewer is seeing only 1 FPS, but If I go to NDPluginBaseFull.adl and set the max array rate it will give me the correct “frame rate”. Seems the camera is running
at 32 FPS but only getting one of them each second. Pylon software is working perfectly with the camera, frame rate can be enabled and set with no problems.
Best Regards,
Abdalla.
- Re: Can't enable custom frame rates for a basler camera in area detector Mark Rivers via Tech-talk
Thorlabs motor controller Siddons, David via Tech-talk
<2021>
<2021>
ANJ, 10 Jan 2021 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
