This looks quite familiar to me, see
https://epics.anl.gov/core-talk/2019/msg00839.php
and the ensuing thread. As mentioned in this thread, there may be a
possible connection to
https://bugs.launchpad.net/epics-base/+bug/1841634
Cheers
Ben
Am 08.01.20 um 21:11 schrieb Mark Rivers via Tech-talk:
> The question is why was the value from the CP link not up to date, i.e. not reflecting the current value of the link PV.
> Andrew thinks this might be due to a known problem with links in 7.0.3.1. If so, I think it needs to be fixed ASAP since it is making my IOC behave incorrectly.
> From: Mark Rivers
> Sent: Tuesday, January 7, 2020 6:42 PM
> To: [email protected]
> Subject: CA link question
> Folks,
> I have an IOC that is in a state I have not seen before. I am trying to understand what it going on.
> This is a calcout record. INPA and INPB are CP links.
> ioc13ida> dbpr "13IDA:eps_wait89",2
> A : 0 ACKS: INVALID ACKT: YES ADEL: 0
> ASG : B : 1 BKPT: 00 C : 0
> CALC: MAX(A,2*B) CLCV: 0 D : 0 DESC: EPS input calc
> DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1
> DLYA: 0 DOPT: Use CALC DTYP: Soft Channel E : 0
> EGU : EVNT: F : 0 FLNK: CONSTANT
> G : 0 H : 0 HHSV: NO_ALARM HIGH: 0
> HIHI: 0 HOPR: 0 HSV : NO_ALARM HYST: 0
> I : 0 INAV: Ext PV OK INBV: Ext PV OK INCV: Constant
> INDV: Constant INEV: Constant INFV: Constant INGV: Constant
> INHV: Constant INIV: Constant INJV: Constant INKV: Constant
> INLV: Constant INPA: CA_LINK 13IDA:eps_bi89.VAL CP NMS
> INPB: CA_LINK 13IDA:eps_invalid.VAL CP NMS INPC: CONSTANT
> INPD: CONSTANT INPE: CONSTANT INPF: CONSTANT INPG: CONSTANT
> INPH: CONSTANT INPI: CONSTANT INPJ: CONSTANT INPK: CONSTANT
> INPL: CONSTANT IVOA: Continue normally IVOV: 0
> J : 0 K : 0 L : 0 LCNT: 0
> LLSV: NO_ALARM LOLO: 0 LOPR: 0 LOW : 0
> LSV : NO_ALARM MDEL: 0 NAME: 13IDA:eps_wait89
> NSEV: NO_ALARM NSTA: NO_ALARM OCAL: 0 OCLV: 0
> ODLY: 0 OEVT: OOPT: Every Time
> OUT : DB_LINK 13IDA:eps_mbbi89.VAL PP NMS OUTV: Local PV
> OVAL: 2 PACT: 0 PHAS: 0 PINI: NO
> POVL: 2 PREC: 0 PRIO: LOW PUTF: 0
> PVAL: 2 RPRO: 0 SCAN: Passive SDIS: CONSTANT
> SEVR: NO_ALARM STAT: NO_ALARM TIME: 2020-01-07 23:35:22.701452929
> TPRO: 0 TSE : 0 TSEL: CONSTANT UDF : 0
> UDFS: INVALID VAL : 2
> value = 0 = 0x0
> Note that INPB is 13IDA:eps_invalid.VAL CP. The current value of B is 1.
> This is 13IDA:eps_invalid. Note that its value is 0.
> ioc13ida> dbpr "13IDA:eps_invalid",2
> CALC: (A#0)||(B=0)||(C#0)||(D#0) CLCV: 0 D : 0
> DESC: EPS invalid calculation DISA: 0 DISP: 0
> DISS: NO_ALARM DISV: 1 DLYA: 0 DOPT: Use CALC
> DTYP: Soft Channel E : 0 EGU : EVNT:
> F : 0 FLNK: CONSTANT G : 0 H : 0
> HHSV: NO_ALARM HIGH: 0 HIHI: 0 HOPR: 0
> HSV : NO_ALARM HYST: 0 I : 0 INAV: Ext PV OK
> INBV: Ext PV OK INCV: Ext PV OK INDV: Ext PV OK INEV: Constant
> INFV: Constant INGV: Constant INHV: Constant INIV: Constant
> INJV: Constant INKV: Constant INLV: Constant
> INPA: CA_LINK 13IDA:eps_bi1.SEVR CP NMS INPB: CA_LINK 13IDA:eps_bi1.VAL CP NMS
> INPC: CA_LINK 13IDA:eps_bi2.VAL CP NMS INPD: CA_LINK 13IDA:eps_bi11.VAL CP NMS
> INPE: CONSTANT INPF: CONSTANT INPG: CONSTANT INPH: CONSTANT
> INPI: CONSTANT INPJ: CONSTANT INPK: CONSTANT INPL: CONSTANT
> IVOA: Continue normally IVOV: 0 J : 0
> K : 0 L : 0 LCNT: 0 LLSV: NO_ALARM
> LOLO: 0 LOPR: 0 LOW : 0 LSV : NO_ALARM
> MDEL: 0 NAME: 13IDA:eps_invalid NSEV: NO_ALARM
> NSTA: NO_ALARM OCAL: 0 OCLV: 0 ODLY: 0
> OEVT: OOPT: Every Time OUT : CONSTANT OUTV: Constant
> OVAL: 0 PACT: 0 PHAS: 0 PINI: NO
> POVL: 0 PREC: 0 PRIO: LOW PUTF: 0
> PVAL: 0 RPRO: 0 SCAN: Passive SDIS: CONSTANT
> SEVR: NO_ALARM STAT: NO_ALARM TIME: 2020-01-08 00:35:15.769533950
> UDFS: INVALID VAL : 0
> My questions:
> - Why is 13IDA:eps_wait89.B 2 if it gets its value from a record whose value is 0, and uses the CP link attribute?
> - If I force 13IDA:eps_wait89 to process with dbtr should it fetch the value of 13IDA:eps_invalid? It does not seem to, B is still 1.
> ioc13ida> dbtr "13IDA:eps_wait89"
> ALST: 2 ASG : B : 1 BKPT: 00
> C : 0 CALC: MAX(A,2*B) CLCV: 0 D : 0
> DESC: EPS input calc DISA: 0 DISP: 0
> INBV: Ext PV OK INCV: Constant INDV: Constant INEV: Constant
> J : 0 K : 0 L : 0 LA : 0
> LALM: 2 LB : 1 LC : 0 LCNT: 0
> LD : 0 LE : 0 LF : 0 LG : 0
> LH : 0 LI : 0 LJ : 0 LK : 0
> LL : 0 LLSV: NO_ALARM LOLO: 0 LOPR: 0
> LOW : 0 LSV : NO_ALARM MDEL: 0 MLST: 2
> NAME: 13IDA:eps_wait89 NSEV: NO_ALARM NSTA: NO_ALARM
> OCAL: 0 OCLV: 0 ODLY: 0 OEVT:
> OOPT: Every Time OUT : DB_LINK 13IDA:eps_mbbi89.VAL PP NMS
> OUTV: Local PV OVAL: 2 PACT: 0 PHAS: 0
> PINI: NO POVL: 2 PREC: 0 PRIO: LOW
> PROC: 1 PUTF: 0 PVAL: 2 RPRO: 0
> SCAN: Passive SDIS: CONSTANT SEVR: NO_ALARM STAT: NO_ALARM
> TIME: 2020-01-08 00:38:43.652867248 TPRO: 0 TSE : 0
> TSEL: CONSTANT UDF : 0 UDFS: INVALID VAL : 2
> value = 0 = 0x0
> Thanks,
> Mark
signature.asc
Description: OpenPGP digital signature
- CA link question Mark Rivers via Tech-talk
- RE: CA link question Mark Rivers via Tech-talk
Re: Ethernet question Hinko Kocevar via Tech-talk
Re: EPICS release series after 7.0: 7.1 or 8.0? J. Lewis Muir via Tech-talk
<2020>
"st.cmd" internal code question 최원철 via Tech-talk
<2020>
