1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: asyn R4-38 available
Date: Fri, 3 Jan 2020 14:55:17 +0000
Folks,
asyn R4-38 is now available.
asyn is available on github here:
https://github.com/epics-modules/asyn
tar and zip files are available here:
https://github.com/epics-modules/asyn/releases
Soon you will be able to find links to the new documentation and release notes here:
https://www.aps.anl.gov/epics/modules/soft/asyn
These are from the R4-38 release notes:
-  devEpics
    -   Added asynInt64 support for longout, longin, ao, and ai records. This allows these
        records to be used to communicate with drivers on the asynInt64 interface. This
        can be useful when running versions of base prior to 3.16.1 where the int64out and
        int64in records are not available. The ao and ai records can exactly represent up
        to 52-bit integers, while the longin and longout are limited to 32-bit integers.
-  FTDI driver</h3>
    -  Fixed missing argument to the iocsh drvAsynFTDIPortConfigure() command
-  drvVxi11
    - Fixed spurious connection error message.
Prev: Epics 7.0.4 java release Shroff, Kunal via Tech-talk
Next: asyn home page moved Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
ANJ, 04 Jan 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
