Yes, that was it. I replaced those files and it fixed the problem.
Hi David,
Ø
EPICS/Release.pm: Undefined macro $(SUPPORT) used
I just realized there could be another cause for this error. Between R3-1 and R3-4 the ADXXX/configure/RELEASE and ADXXX/iocs/XXXIOC/configure/RELEASE files need to change. Look at those 2 files in ADSimDetector for examples.
Hi David,
In the RELEASE.md for R3-3 it describes changes to the areaDetector/configure/RELEASE*.local files.
https://github.com/areaDetector/areaDetector/blob/master/RELEASE.md
The EXAMPLE_RELEASE*.local files were updated to reflect the required changes.
The INSTALL_GUIDE.md explains what is required in these files.
https://github.com/areaDetector/areaDetector/blob/master/INSTALL_GUIDE.md
I have an area detector module (github.com/djvine/ADTucsen) that builds without any problem on AD3-1 but on AD3-4 I get the message below
about an undefined macro $(SUPPORT).
Any suggestion on how to fix would be greatly appreciated.
[david@dusk ADTucsen]$ make clean && make
at /opt/epics/base-3.15.5/bin/linux-x86_64/../../lib/perl/EPICS/Release.pm line 104.
main::expandRelease(HASH(0x558e9a7f3100)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./configure clean
make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/configure'
main::expandRelease(HASH(0x55b054e11588)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
rm -rf O.linux-x86_64 O.Common
make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/configure'
make -C ./tucsenSupport clean
make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenSupport'
main::expandRelease(HASH(0x555f2675e588)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenSupport'
make -C ./tucsenApp clean
make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp'
main::expandRelease(HASH(0x555c9188d5b8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./src clean
make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/src'
main::expandRelease(HASH(0x55c6cb9455e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/src'
make -C ./Db clean
make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/Db'
main::expandRelease(HASH(0x55d4be52b5b8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/Db'
make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp'
make -C ./iocs clean
make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs'
main::expandRelease(HASH(0x562d950535b8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./tucsenIOC clean
make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC'
main::expandRelease(HASH(0x55fd353095e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/configure'
main::expandRelease(HASH(0x557b115ea5e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/configure'
make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/tucsenApp'
main::expandRelease(HASH(0x55eb8ef845d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./src clean
make[4]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/tucsenApp/src'
main::expandRelease(HASH(0x55ef355215e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[4]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/tucsenApp/src'
make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/tucsenApp'
make -C ./iocBoot clean
make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/iocBoot'
main::expandRelease(HASH(0x55c6f0b525e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./iocTucsen clean
make[4]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/iocBoot/iocTucsen'
main::expandRelease(HASH(0x563c802b25e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
rm -f cdCommands envPaths dllPath.bat relPaths.sh
make[4]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/iocBoot/iocTucsen'
make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/iocBoot'
make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC'
make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs'
main::expandRelease(HASH(0x562e3bf75030)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./configure install
main::expandRelease(HASH(0x561594de95e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
perl -CSD /opt/epics/base-3.15.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
T_A=linux-x86_64 install
make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/configure/O.linux-x86_64'
main::expandRelease(HASH(0x55c621a125d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
perl -CSD /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl checkRelease
main::expandRelease(HASH(0x5582794649d0)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/configure/O.linux-x86_64'
make -C ./tucsenSupport install
main::expandRelease(HASH(0x5631918655b8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
mkdir O.Common
make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenSupport/O.linux-x86_64'
main::expandRelease(HASH(0x560dc1eb95e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenSupport/O.linux-x86_64'
make -C ./tucsenApp install
main::expandRelease(HASH(0x55b0968485d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./src install
main::expandRelease(HASH(0x55d6e58315d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
perl -CSD /opt/epics/base-3.15.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/src/O.linux-x86_64'
main::expandRelease(HASH(0x55609453e5e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../
../include/os/Linux -I../../../include -I/opt/epics/synApps/support/asyn-R4-33/include -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps/support/areaDetector
-master/ADSupport/include -I/opt/epics/synApps/support/areaDetector-master/ADCore/include -I/opt/epics/base-3.15.5/include/compiler/gcc -I/opt/epics/base-3.15.5/include/os/Linux -I/opt/epics/base-3.15.5/inclu
de -MM -MF tucsen.d ../tucsen.cpp
main::expandRelease(HASH(0x55baae33e630)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
de -c ../tucsen.cpp
../tucsen.cpp: In member function ‘asynStatus tucsen::grabImage()’:
../tucsen.cpp:410:9: warning:
variable ‘header’ set but not used [-Wunused-but-set-variable]
int header, offset;
../tucsen.cpp:411:23: warning:
variable ‘stride’ set but not used [-Wunused-but-set-variable]
int nCols, nRows, stride;
../tucsen.cpp:412:42: warning:
variable ‘pixelBytes’ set but not used [-Wunused-but-set-variable]
int bitDepth, pixelFormat, channels, pixelBytes;
../tucsen.cpp:413:9: warning:
variable ‘index’ set but not used [-Wunused-but-set-variable]
int index, dataSize;
../tucsen.cpp: In member function ‘virtual asynStatus tucsen::writeInt32(asynUser*, epicsInt32)’:
../tucsen.cpp:551:9: warning:
variable ‘tucStatus’ set but not used [-Wunused-but-set-variable]
int tucStatus;
../tucsen.cpp: In member function ‘virtual asynStatus tucsen::writeFloat64(asynUser*, epicsFloat64)’:
../tucsen.cpp:632:24: warning:
unused variable ‘functionName’ [-Wunused-variable]
static const char* functionName = "writeFloat64";
../tucsen.cpp:633:17: warning:
unused variable ‘paramName’ [-Wunused-variable]
const char* paramName;
../tucsen.cpp: In member function ‘asynStatus tucsen::setCamInfo(int, int, int)’:
../tucsen.cpp:677:24: warning:
static const char* functionName = "setCamInfo";
../tucsen.cpp: In member function ‘asynStatus tucsen::setSerialNumber()’:
../tucsen.cpp:711:24: warning:
static const char* functionName = "setSerialNumber";
../tucsen.cpp: In member function ‘asynStatus tucsen::startCapture()’:
../tucsen.cpp:792:24: warning:
static const char* functionName = "startCapture";
../tucsen.cpp: In member function ‘asynStatus tucsen::stopCapture()’:
../tucsen.cpp:802:24: warning:
static const char* functionName = "stopCapture";
../tucsen.cpp:803:9: warning:
int tucStatus;
../tucsen.cpp: At global scope:
‘functionName’ defined but not used [-Wunused-variable]
../tucsen.cpp:418:9: warning:
‘pixelSize’ may be used uninitialized in this function [-Wmaybe-uninitialized]
int pixelSize;
../tucsen.cpp:493:5: warning:
‘numColors’ may be used uninitialized in this function [-Wmaybe-uninitialized]
if (numColors==1){
../tucsen.cpp:520:32: warning:
‘dataType’ may be used uninitialized in this function [-Wmaybe-uninitialized]
pRaw_ = pNDArrayPool->alloc(nDims, dims, dataType, 0, NULL);
/usr/bin/ar -rc libtucsen.a tucsen.o
/usr/bin/ranlib libtucsen.a
Installing library ../../../lib/linux-x86_64/libtucsen.a
make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/src/O.linux-x86_64'
make -C ./Db install
main::expandRelease(HASH(0x556cac1205e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
mkdir O.Common
make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/Db/O.linux-x86_64'
main::expandRelease(HASH(0x555b4686a5b8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/Db/O.linux-x86_64'
make -C ./iocs install
main::expandRelease(HASH(0x557ad1e775d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./tucsenIOC install
main::expandRelease(HASH(0x55f0880d15d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
main::expandRelease(HASH(0x5641de5fd5d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
mkdir O.Common
make[4]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/configure/O.linux-x86_64'
main::expandRelease(HASH(0x555dead625e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
main::expandRelease(HASH(0x563577ae9c88)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
main::expandRelease(HASH(0x563577b138f8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 222
main::checkRelease called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 86
make[4]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/configure/O.linux-x86_64'
main::expandRelease(HASH(0x562acc1675d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
main::expandRelease(HASH(0x560f5669c5d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
mkdir O.Common
make[5]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/tucsenApp/src/O.linux-x86_64'
main::expandRelease(HASH(0x556d8dd6a5a8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../in
clude/os/Linux -I../../../include -I../../../../../include -I/opt/epics/synApps/support/asyn-R4-33/include -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApp
s/support/areaDetector-master/ADSupport/include -I/opt/epics/synApps/support/areaDetector-master/ADCore/include -I/opt/epics/synApps/support/autosave-R5-9/include/os/Linux -I/opt/epics/synApps/support/autosa
ve-R5-9/include -I/opt/epics/synApps/support/busy-R1-7/include -I/opt/epics/synApps/support/calc-R3-7-1/include -I/opt/epics/synApps/support/seq-2-2-5/include -I/opt/epics/synApps/support/sscan-R2-11-1/
include -I/opt/epics/synApps/support/iocStats-3-1-15/include/os/Linux -I/opt/epics/synApps/support/iocStats-3-1-15/include -I/opt/epics/base-3.15.5/include/compiler/gcc -I/opt/epics/base-3.15.5/include/os/Linu
x -I/opt/epics/base-3.15.5/include -MM -MF tucsenAppMain.d ../tucsenAppMain.cpp
Creating dbd file tucsenApp.dbd
perl -CSD /opt/epics/base-3.15.5/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/opt/epics/synApps/support/asyn-R4-33/dbd -I/opt/epics/synApps/support/areaDetector-
master/ADCore/dbd -I/opt/epics/synApps/support/autosave-R5-9/dbd -I/opt/epics/synApps/support/busy-R1-7/dbd -I/opt/epics/synApps/support/calc-R3-7-1/dbd -I/opt/epics/synApps/support/seq-2-2-5/dbd -I/opt/epics/s
ynApps/support/sscan-R2-11-1/dbd -I/opt/epics/synApps/support/iocStats-3-1-15/dbd -I/opt/epics/base-3.15.5/dbd -o tucsenApp.dbd tucsenSupport.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDFile
NetCDF.dbd NDFileMagick.dbd NDFileTIFF.dbd NDFileJPEG.dbd NDFileNexus.dbd NDFileHDF5.dbd asyn.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd
perl -CSD /opt/epics/base-3.15.5/bin/linux-x86_64/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/opt/epics/synApps/support/asyn-R4-33/dbd -I/opt/epics/synApps/supp
ort/areaDetector-master/ADCore/dbd -I/opt/epics/synApps/support/autosave-R5-9/dbd -I/opt/epics/synApps/support/busy-R1-7/dbd -I/opt/epics/synApps/support/calc-R3-7-1/dbd -I/opt/epics/synApps/support/seq-2-2-5/d
bd -I/opt/epics/synApps/support/sscan-R2-11-1/dbd -I/opt/epics/synApps/support/iocStats-3-1-15/dbd -I/opt/epics/base-3.15.5/dbd -o tucsenApp_registerRecordDeviceDriver.cpp ../O.Common/tucsenApp.dbd tucsenApp
_registerRecordDeviceDriver /opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC
x -I/opt/epics/base-3.15.5/include -MM -MF tucsenApp_registerRecordDeviceDriver.d tucsenApp_registerRecordDeviceDriver.cpp
main::expandRelease(HASH(0x56454ea9a630)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
- AreaDetector R3-4 module build error David Vine via Tech-talk
- Re: AreaDetector R3-4 module build error Mark Rivers via Tech-talk
- RE: AreaDetector R3-4 module build error Mark Rivers via Tech-talk
Cannot execute application on ARM target 刘佳 via Tech-talk
<2019>
proxy authentication for standard cs-studio Jignesh Patel via Tech-talk
<2019>
ANJ, 11 Jan 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
