Hi Mark,
I am intending to implement a driver for an FPGA-based device based on
asynPortDriver. One of the features my IOC should support is
reading/writing FPGA firmware from/to the device using waveform records.
My device supports reading/writing the firmware in small blocks.
Reading/writing a single block doesn't take too long but writing the
whole image can take a few minutes.
Here is what I have in mind:
- Set ASYN_CANBLOCK
1. Client reads firmware image from file, caputs it to the waveform record.
2. Asyn calls writeInt8Array in my driver which copies the data,
notifies the waveform-writer thread and returns. This releases the Asyn
lock and ensures other records can communicate with the device.
3. The waveform-writer thread iterates over the image and writes it
block-by-block in the background. I guess I need to acquire and release
some lock for each write operation to ensure these commands do not get
mixed up with communication initiated by other records. Would the
asynPortDriver::lock/unlock methods be the right way to handle this?
4. Once the waveform-writer thread is done it calls back Asyn to report
completion.
- For writes to simple registers the write function writes the data
immediately and calls Asyn to report completion.
Is this the right approach? Can you point me to drivers that I could use
as an example?
Thanks a lot,
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
- RE: Asyn: example driver for slow device? Mark Rivers
RE: vxWorks 6.9 compiler problem on large file systems Mark Rivers
Asyn and devices with changing register map Konrad, Martin
<2017>
<2017>
