Hi Oleg,
On 01/10/2014 10:31 AM, Oleg A. Makarov wrote:
> I encounter an error while building an EPICS 3.14.12.4 base with
> vxWorks-6.9 for the case of
> CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc604_long, see error messages below.
> Same problem observed for the case of
> CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc604.
> EPICS base builds with no errors for the case of
> CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc603.
> The differences in the ccppc cross compiler args are:
> -mcpu=604 -fno-implicit-fp -mlongcall
> -mcpu=603
> Any suggestions?
If you switch to the target vxWorks-ppc32 instead on VxWorks 6.x, you
can use that for all 32-bit PowerPC boards except for the MVME3100
(which needs the vxWorks-ppc32sf target because it doesn't have hardware
floating-point instructions). That is the target we use for the APS
accelerator IOCs on VxWorks 6.
The main difference between the ppc604 and the ppc32 seems to be the
absence of the -mno-implicit-fp flag, but I would recommend changing
targets instead, to cut down on the build time.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- EPICS 3.14.12.4 base with vxWorks-6.9 compile error for the ppc604_long target Oleg A. Makarov
Driver for PiXirad pixel array detector Mark Rivers
<2014>
<2014>
