1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Asyn AutoConnect and stream device on a soft IOC
To: [email protected]
Date: Thu, 22 Aug 2013 15:34:23 -0600
We've been running a soft IOC that talked to a number of ethernet based devices. We've been using the auto-reconnect feature of asyn, and generally it works. However we often have problems where a device is unreachable on the network, and apparently asyn will try to reconnect to it many times in rapid succession, the end result is that the load on one cpu core will reach 100%. At this point even if the device is reconnected to the network the IOC will not successfully reconnect.
Has any one else had this problem, or no how to avoid it.
Probably, I could turn off autoreconnect and have a record that requests reconnects at a specified maximum rate as needed. I'm wondering if there's some setting that I've missed that limits how quickly asyn will attempt to reconnect.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
RE: Asyn AutoConnect and stream device on a soft IOC Mark Rivers
Prev: Re: streamdevice to find the last match Benjamin Franksen
Next: RE: Asyn AutoConnect and stream device on a soft IOC Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Problems compiling Nexus library as DLL on Windows Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
