Hi Brian,
On 2013-06-27 Brian McAllister wrote:
> I still don't understand why it didn't work from the local host. iptables
> accepts all traffic from the loopback. Why doesn't that work for CA ?
It would have if you had added the loop-back address to EPICS_CA_ADDR_LIST;
by default CA deliberately excludes that from the list of interfaces it sends
searches to. That exclusion makes perfect sense for VxWorks IOCs since there
is an internal short-cut between the client library and the RSRV for local
channels so there is no point sending search requests to yourself, that would
just be wasting CPU time.
For workstations where the CA server is in a different process sending
searches to the sub-net's broadcast address will still result in local
servers seeing the searches, so loop-back is not needed there either. Maybe
CA should include the loop-back address if there are no other interfaces
available, but that wouldn't have helped your case anyway because there was
one, it was just fire-walled off.
You can find out more about the CA protocol in these slides:
http://www.aps.anl.gov/epics/docs/AES2013/11-Protocol.pdf
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: caget can't connect to soft ioc on host with multiple NICs Brian McAllister
Re: Record Processing Zenon Szalata
Re: caget apparent timeout Andrew Johnson
<2013>
Re: caget can't connect to soft ioc on host with multiple NICs Dirk Zimoch
<2013>
