Hi Lewis,
On 2013-06-20 J. Lewis Muir wrote:
> Right, I understand that. But I'm (not very clearly) asking about the
> case of writing to a file from an IOC using errlog and not depending on
> another host. Are you saying one can run iocLogServer on the same host
> as the iocLogClient? Will this work on vxWorks too? I hadn't thought
> of doing that. This would be a new way (to me anyway) of writing to a
> file from one IOC using errlog without depending on another host.
You could definitely do that on any workstation OS. The current
iocLogServer.c source code wasn't designed for VxWorks because it has a
main() function, but there's nothing that inherently prevents you from
running a similar server on VxWorks. I would probably want to be sure the
log file was on an NFS-mounted drive and that the server's task priority is
sufficiently low to not interfere with the IOC threads, but I don't see any
other problems.
It appears that feller may not allow you to write errlog messages that don't
have its special header in them. If you just want to run a local version of
the iocLogServer it would be more efficient to write another errlog listener
program that does the file-writing directly; funneling the messages through a
TCP socket to a separate local server process is going to waste time
switching thread contexts which is probably not necessary.
> OK, so here's where I could benefit from using feller: If my goal was to
> write to a file using errlog from an IOC and *not* run iocLogServer at
> all (i.e. not on the same host nor any other host), I could use feller
> to do this. I think I've got it.
I haven't looked at Benjamin's code so I don't know for sure if that's what
he has implemented, but we usually think enough alike that I suspect that's
what feller does.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- seqLog obsolete / errlog filtering based on source Emmanuel Mayssat
- Re: New EPICS support module "feller", release 0.1 Andrew Johnson
- Re: New EPICS support module "feller", release 0.1 J. Lewis Muir
RE: New EPICS support module "feller", release 0.1 Mark Rivers
Re: help setting up XY table control with EPICS StreamerClass Christian Pauly
<2013>
Re: New EPICS support module "feller", release 0.1 Benjamin Franksen
<2013>
