On 5/29/13 5:43 PM, Andrew Johnson wrote:
> Hi Lewis,
> On 2013-05-29 J. Lewis Muir wrote:
>> The error looks like it's coming from the autosave module. I'm guessing
>> maybe the RPC error suggests something wrong with communicating with the
>> NFS server where the auto_settings.sav file is being written, but I
>> don't know. The NFS server log doesn't show any problem. Once the
>> problem starts, it doesn't seem to go away until I reboot the IOC.
> Once it has started, does an 'ls' (or any other file operation) at the IOC
> console work against the NFS disk?
Hi, Andrew.
I don't know; I've never tried that. I'll try it the next time it happens.
Well, hold that thought. I just tried an 'ls' right now on the IOC
while it is not exhibiting the RPC problem, and it does not work.
Here's the output:
=== console ===
ioc> ls
imcais-sim.template
error reading dir , errno: 0x300016
value = -1 = 0xffffffff
There are actually 45 entries (files or directories) in the current
working directory, and it only listed one of them (imcais-sim.template)
before reporting an error.
>> This problem has not always existed; it used to work fine. I initially
>> thought it was a problem with autosave 5-0, since it seemed the problem
>> showed up for the first time after I had upgraded to 5-0. But then I
>> rolled back to 4-8, and the problem is still appearing. It's possible
>> the NFS server changed somehow, or maybe a network adapter, cable,
>> switch, etc. is failing, or none of these.
> We have seen other problems ('ls' failing) against a Linux NFS server when
> using NFSv3, but this problem goes away if we revert back to NFSv2. You can
> select the NFS version if you're mounting the drive manually, just use the
> nfs2Mount (or nfs3Mount) command instead of nfsMount. However autosave calls
> nfsMount automatically in some cases which Tim Mooney can explain (probably
> related to I/O failures) and that could undo the manual mount.
Interesting.
> I would prefer to fix the problem inside the NFSv3 code, but that could take
> some time so in the meanwhile I've produced some OS images that don't contain
> the NFSv3 client. I can send you a copy of the mv5100 image if you want to
> see if that helps.
Using nfsstat on the NFS server, I can confirm that the IOC NFS client
is using NFSv3. Yes, if you'd be willing, I would love it if you could
send that image! I'd like to try that to see if it helps.
Thanks!
Lewis
- RE: autosave failure S_rpcLib_RPC_CANTSEND Mark Rivers
- Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
- autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
- Re: autosave failure S_rpcLib_RPC_CANTSEND Andrew Johnson
Re: EPICS on an embedded device So, Sung-Leung
<2013>
<2013>
