Hi Emma,
I agree. The original purpose of RDBD was specifically about retries,
and not also about whether or not to make an initial move. I would
like to explore the consequences of going back to that purpose.
Tim
----- Original Message -----
> From: "Emma Shepherd" <[email protected]>
> To: [email protected]
> Sent: Monday, May 27, 2013 5:57:25 PM
> Subject: Motor record .RDBD field
> Hi all,
> I've stumbled into this issue a couple of times now so I thought it
> was worth a message to tech-talk.
> The .RDBD field of the motor record limits the smallest allowed move
> - quite often we want to set this very low so that we can do small
> step moves. However, in a few cases we also want to use the motor
> record's retry mechanism by setting .UEIP to 'Yes' and feeding the
> encoder into .REP (I'm using the tpmac driver which allows you to do
> this when the encoder is on a different channel). Because .RDBD is
> now used as the retry deadband, we need to make it larger since it
> is not capable of attaining such an accurate position.
> It would be better if we could somehow decouple the use of .RDBD in
> the retry sense from the smallest allowed move. Have other people
> run into this and found a solution? In the meantime I need to keep
> switching between modes (toggling .UEIP and changing .RDBD
> appropriately) to allow me to do scans in very small steps followed
> by a wind-back which uses retries to ensure I'm not losing steps.
> It's a bit messy and not ideal.
> Of course if we had perfect mechanics we wouldn't need to be doing
> retries at all, but c'est la vie!
> Thanks,
> Emma
> P.S. I hope I haven't missed a thread on this already, the APS
> website seems to be down at the moment so I can't check
> SUPPLIERS: As of 1 January 2013, the Australian Synchrotron Company
> Ltd has changed its business name. However, the trading name will
> remain Australian Synchrotron.
> Please address all quotations and invoices to: Synchrotron Light
> Source Australia Pty Ltd (SLSA), ABN: 18 159 468 256
- Re: Motor record .RDBD field Pearson, Matthew R.
- Motor record .RDBD field Emma Shepherd
Re: streamdevice Dirk Zimoch
<2013>
<2013>
