> Would it be reasonable to apply the '-0' options to CHAR types too?
And to DOUBLEs also? I'd like to see my unsigned long fields as hex but they come in as DOUBLE due to CA.
Thank you,
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Eric Norum
> Sent: Wednesday, May 08, 2013 9:54 AM
> To: [email protected] Talk
> Subject: camonitor ignores format arguments for CHAR data
> 'camonitor -h' reports:
> Integer number format:
> Default: Print as decimal number
> -0x: Print as hex number
> -0o: Print as octal number
> -0b: Print as binary number
> But attempting to use this with a UCHAR waveform record has no effect.
> $ camonitor -0x koherasE15test:BasiK:Register10
> koherasE15test:BasiK:Register10 2013-05-08 09:43:51.018324 28 126 0 103 78 0 0
> -59 0 8 95 0 0 0 0 -106 1 17 0 -1 0 -124 9 -72 47 -77 6 22 6
> koherasE15test:BasiK:Register10 2013-05-08 09:43:53.018341 28 126 0 105 78 0 0
> is the the same as without the '-0x':
> $ camonitor koherasE15test:BasiK:Register10
> koherasE15test:BasiK:Register10 2013-05-08 09:43:19.010327 28 126 0 105 78 0 0
> -60 0 8 95 0 0 0 0 -106 1 17 0 -1 0 -124 9 -72 47 -77 6 22 6
> koherasE15test:BasiK:Register10 2013-05-08 09:43:21.010336 28 126 0 105 78 0 0
> -59 0 8 95 0 0 0 0 -106 1 16 0 -1 0 -124 9 -72 47 -77 6 22 6
> The code in R3.14.12/base/src/catools/ makes it clear why this is the case. The tool_lib.c
> code has
> switch (base_type) {
> case DBR_CHAR:
> ch = ((dbr_char_t*) val_ptr)[index];
> sprintf(str, "%d", ch);
> break;
> case DBR_INT:
> sprint_long(str, ((dbr_int_t*) val_ptr)[index], outTypeI);
> break;
> case DBR_LONG:
> sprint_long(str, ((dbr_long_t*) val_ptr)[index], outTypeI);
> break;
> Eric Norum
> [email protected]
- Re: camonitor ignores format arguments for CHAR data Andrew Johnson
- camonitor ignores format arguments for CHAR data Eric Norum
<2013>
<2013>
