1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Maven central and deprecating sourceforge maven repo
Date: Mon, 4 Mar 2013 13:58:28 +0000
Hi all,
We have started publishing jca/caj/pvmanager in maven central:
http://search.maven.org/#search|ga|1|g%3A%22org.epics%22
Which means: no need to configure a repository and we get an index (you can search). The same repository can also be used, as before, with apache ivy or to manually download the jars.
Snapshots (dev builds) are being published at:
https://oss.sonatype.org/content/repositories/snapshots/org/epics/
which automatically removes older versions. If you want to use them, you’ll have to explicitly add:
<repositories>
  <repository>
    <id>sonatype-nexus-snapshots</id>
    <name>Sonatype Nexus Snapshots</name>
    <url>https://oss.sonatype.org/content/repositories/snapshots</url>
    <releases>
      <enabled>false</enabled>
    </releases>
    <snapshots>
      <enabled>true</enabled>
    </snapshots>
  </repository>
</repositories>
But most of you will not.
The groupId for the coordinates had to change to “org.epics” as per the maven best practices, but they allowed us to publish libraries under that groupId even though their package does not match.
The plan would be to remove the old repository once we finished moving pvaccess/pvdata. If this conflicts with somebody else’s plan, please let me know.
Thanks!
Gabriele
Prev: Re: Installing MEDM on UBUNTU 12.04 Kohler
Next: Recommendations for developing an IOC for PCI Igor H. Soares Nunes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Crystal Logic goniometer Myers, Stuart F
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
