I've never been brave enough to hack code into the waveform record support. Instead I FLNK the waveform record to a longin record which gets its value from the waveform record NORD field and posts monitors as required.
On Feb 28, 2013, at 9:34 AM, Andrew Johnson <[email protected]> wrote:
> Hi Gary,
> On 2013-02-28 Carr, Gary wrote:
>> I have an application that needs to monitor changes in the NORD field of a
>> waveform record. Since we are running Channel Access 3.14.11, I cannot get
>> a monitor on the field, so I use a simple "get" to poll the field in Java.
>> Basically:
>> Channel ic = context.createChannel("pvname.NORD");
>> context.pendIO(timeout);
>> int val = ((INT) ic.get(DBRType.INT,1)).getValue();
>> Using jca context this works fine either reading thechannel directly, or
>> through a CA gateway. If I use a caj context in the same code, it works
>> fine reading the channel directly, but if I read through a CA gateway I
>> never see the NORD field change when the waveform processes.
> That's because the gateway sets up a monitor on the channel and uses that
> value when you do a ca_get from it. It does that to try and reduce the load
> on the IOCs if lots of scripts do ca_get operations on random channels.
> There may be a flag you can give the gateway to prevent that behavior (but it
> will increase the load on your IOCs), or you could patch the waveform record
> in Base to make it post monitors on NORD — we've done that in the 3.15 branch,
> and it's just a one-line change (line-numbers may vary):
> === modified file 'src/std/rec/waveformRecord.c'
> --- src/std/rec/waveformRecord.c 2010-10-05 19:27:37 +0000
> +++ src/std/rec/waveformRecord.c 2012-02-17 23:32:25 +0000
> @@ -191,6 +191,7 @@
> if (prec->nord > prec->nelm)
> prec->nord = prec->nelm;
> + db_post_events(prec, &prec->nord, DBE_VALUE | DBE_LOG);
> return 0;
> - Andrew
> There is no such thing as a free lunch. When invited for lunch,
> it is best to check if you are there to eat, or to be eaten.
> -- Clive Robinson
Eric Norum
[email protected]
- Strange Interaction between CA gateway and CAJ Carr, Gary
- Re: Strange Interaction between CA gateway and CAJ Andrew Johnson
Re: Problem building EPICS 3.14.12.3 on Cygwin J. Lewis Muir
<2013>
areaDetector R1-9 released Mark Rivers
<2013>
