You are using the Java Native Interface (JNI) which requires a shareable library on your host. What happens if you use the pure-Java interface by using this call instead:
ctx=jca.createContext(JCALibrary.CHANNEL_ACCESS_JAVA);
Hello, all
I'm trying to execute the simple example using JCA, to implement a channel access client in Java, but doesn't work.
The main function of my class (SimpleJCAGet):
SimpleJCAGet simpleJCAGet = new SimpleJCAGet();
JCALibrary jca=null;
Context ctxt=null;
Channel chan=null;
if(!simpleJCAGet.parseCommand(args)) System.exit(1);
if(!simpleJCAGet.pvSpecified) {
System.err.println("No PV specified\n");
System.exit(1);
try {
jca=JCALibrary.getInstance();
ctxt=jca.createContext(JCALibrary.JNI_SINGLE_THREADED);
chan=ctxt.createChannel(simpleJCAGet.name);
ctxt.pendIO(simpleJCAGet.timeout);
} catch(Exception ex) {
System.err.println(ex);
System.exit(1);
In this point (chan=ctxt.createChannel(simpleJCAGet.name)), he throws an exception: "java.lang.IllegalStateException: Context not initialized".
The doc (
http://www.aps.anl.gov/bcda/jca/jca/2.1.2/api/gov/aps/jca/Context.html#createChannel%28java.lang.String%29 ) says: " java.lang.IllegalStateException - if the context has been destroyed." , but the context was created in the previous row.
The files are correct, the IOC is running corretly, and this example is in page of JCA. What could be wrong?
Thanks (And sorry my english)!
Lucas José
- RE: JCA Error Lucas José
- JCA Error Lucas José
Re: What I learned today... Michael Davidsaver
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
