I was wondering where I might be able to find more information on
fileDescriptorManager.process. I am using this command as illustrated in
the examples to process events for a portable channel access server. Is
there a way to do this without calling it periodically? I seem to be
running into trouble doing this, because when I call it in a loop with
ca_poll, (or a usleep of more than 100000) it does not appear to be called
often enough and caget will time out trying to connect to channels in the
pcas.
Thank you,
Patrick
> Hi Xiaoqiang,
> Thank you for your response. I think it turns out that the problem was
> that I actually had preemptive callback enabled and I should not have. I
> think with preemptive callback enabled, the callback functions were being
> run while the fileDescriptorManager.process was processing. Now they only
> run when I call ca_poll or ca_pend_event, which I can separate from
> -Patrick
>> Hi,
>> It is difficult to say anything without looking at your source.
>> But one thing come to my mind is, you are using
>> fileDescriptorManager.process to poll for updates.
>> It would be good to test again using preemptive callback in caCleint
>> code.
>> Check here for more infos.
>> http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#Thread
>> On the other hand, if you are not bound to use C++,
>> one can write such an application in Python, like I just did, in 3
>> minutes, 33 lines of code.
>> It uses module PCASpy[1] for PCAS server programming.
>> I use module CaChannel[2] for caClient, but other modules[3] should work
>> the same.
>> Best
>> Xiaoqiang
>> [1] https://code.google.com/p/pcaspy/
>> [2]
>> http://controls.web.psi.ch/cgi-bin/twiki/view/Main/NewPythonEpicsInterface
>> [3] http://www.aps.anl.gov/epics/extensions/index.php
>> On Feb 22, 2013, at 8:00 PM, [email protected] wrote:
>>> Hi,
>>> I am trying to add a portable channel access server to a channel access
>>> client, similar to the EPICS gateway I believe. The values for the
>>> process
>>> variables that are created by the PCAS are written to from the
>>> connection
>>> and event handler callbacks for the caClient. The problem I think I am
>>> running into, is that when I call fileDescriptorManager.process, these
>>> callbacks get called similar to as if a ca_pend_event was called. So
>>> after
>>> the call to fileDescriptorManager.process and before it completes, new
>>> values are being written to the PCAS process variables, and postEvent
>>> is
>>> being called for these changed values. This leads to funny behavior
>>> where
>>> the same value is posted for a PCAS channel multiple times in a row (as
>>> seen with camonitor). For example, it should post 1, 2, 3 but posts 3,
>>> 3,
>>> 3 instead, all with the same time stamps. Is there a way around this?
>>> I also ran a test, with just the PCAS and leaving out the caClient. I
>>> wrote to a PCAS process variable continuously with increasing values in
>>> one thread and called fileDescriptorManager.process continuously in
>>> another thread. This gave me similar results, that is the same value
>>> was
>>> posted multiple times in a row for stretches of time before it
>>> increased.
>>> I was not surprised that I got funny behavior doing this, but the fact
>>> that it was similar to the caClient helped me diagnose what may be
>>> happening.
>>> Also, what is the usual way to update the values for the PCAS process
>>> variables from the application itself (i.e. not with a caput)? I added
>>> a
>>> public function to the PCAS Server that calls functions in the
>>> appropriate
>>> PV instance to write a value and call the postEvent function. Is this
>>> typical? If so, I am guessing that I should also check in this function
>>> to
>>> see if the new value will actually be different before writing it, so
>>> that
>>> postEvent is not called when the value has not really changed? Or is
>>> there
>>> another way to do that?
>>> Thank you for your time,
>>> Patrick
- Re: caClient with PCAS Xiaoqiang Wang
- caClient with PCAS pthomas
- Re: caClient with PCAS pthomas
CA client on iOS? Pavel Maslov
<2013>
<2013>
