Subject: |
Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 |
Dirk Zimoch <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 25 Feb 2013 15:51:53 +0100 |
On 22.02.2013 17:02, Andrew Johnson wrote:
The error being reported is that GNUmake can't find the program 'podchecker'
which should be part of your Perl installation. However by this point in the
build it has already compiled and installed everything that can be built on
Windows, so you can ignore this error. If you don't want to see it in the
future, you can comment out this line from the base/src/Makefile:
DIRS += cap5
- Andrew
I had to comment out cap5 for several cross linux architectures. (which
I build as "HOST" architecture in order to have caget and friends.) Also
if the compiler you use to build EPICS is not the one that was used to
build perl you get into trouble.
Do we really need cap5 in EPICS base? I would like to see it in a
separate module.
Dirk
- Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 J. Lewis Muir
- Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Andrew Johnson
- Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 王林
Re: Problem when loading epics3.14.12.1 application to vxWorks5.5/MPC8572 Dirk Zimoch
<2013>
<2013>
